SLED GUITARIST
Tall 5th feeler
I had a tall 5th in my 85.5 and loved it. Does someone in the ca bay area have one, 85.5, maybe consider a trade for a 944s non-lsd? I have a AGP currently installed. Looking for 5S, 7V,
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2 1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan 1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD ![]() |
if you mean the .729 ratio 5th gear, i have a broken early NA trans (busted diff, gears are fine) you could take for $75. i could have my brother bring it to you as he lives in SF.
SLED GUITARIST
I was hoping for an later TA
Greasy Member
If you want a set of tall 5th gears, I have PLENTY!!! we always swap them out for the short set on the race cars. I'd be more than happy to send you a set for $20 plus shipping!!!
LMK! -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
SLED GUITARIST
I not sure if i am comfortable another tearing a ta apart yet. Although I am rebuilding my chevy nvg4500 manual transmission. I also liked the smaller 2,3,4 gearing of the 5S. Great pick up around town and 27-30 mpg on the hwy.
Greasy Member
Really, it's not bad... here is goes:
-procure replacement rear cap -Unbolt axles -Un bolt coupler on trans input shaft & slide back -unbolt trans mount(s) -remove trans from car -remove rear tail housing -remove retaining bolts -remove short 5th gears -install tall 5th gears -install tailhousing -intstall new rear cap-plug -reverse removal -drive like you stole it... with better gas mileage ![]() We do it twice a week to swap in shorts for talls on race cars!! -Nick
SLED GUITARIST
Sounds easy when you put it like that. I will consider.
Greasy Member
Honestly... with 2 guys it can be done in 1 hour, removal, swap, and re-install!
-Nick
SLED GUITARIST
No need to remove the shaft?
Greasy Member
Remove the shaft??
There is no need to part the main case to swap the 5th gear!! The entire 5th gear is located in the rear aluminum tail-housing. You dont have to separate the main case to swap it... Its really quite simple! -Nick
SLED GUITARIST
I know this might sound funny, but can you swap 5th with the trans still in?
Greasy Member
Ummm, yes. it can be done... however it requires the spare tire well to be removed! There is not enough clearance to remove the tail housing while the trans is still in the car
![]() -Nick
SLED GUITARIST
Ok, my wife says when my 944S engine sales, I can get it.
SLED GUITARIST
Ok Nick email sent.
Nick,
I sent you a PM.
Sasquatch 1987 Porsche 944 1974 Porsche 914 "Don't retreat, reload." Sarah Palin |
SLED GUITARIST
Nick where are you?
All Spooled Up
What exactly IS the rear cap? I am also going to this precedure at some point. I already have the gear set to put in it .
Being able to do it with the trans still in the car does appeal to me. But I don't understand how removing the spare tire will provide more room UNDER the car. Isn't there a well for the spare that sticks down down behind the transaxle? The well would have to be at least bashed in at the front side to provide enough clearance for the rear housing to be removed, wouldn't it??
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
SPD
1984 944 "Elka" Ford 5.0 |
Comeau Racing
Dan,
A 944S AGP tranny would make a regular 944 a dog. Taller 1st thru 4th gear! The tranny is in 3 pieces. The front aluminum body, the cast iron gear carrier assy, then the aluminum tail section or nose cone. The tail section is where the 5th gear pair is located, as Nick stated, and there's not enough room to move it straight backwards for removal without striking the spare tire well. Don't butcher your 944/924S by trying to do this job with the tranny in the car.
PCA since 1985 77 924 MARTINI Edition rescued,SOLD 88 924S Special Edition rescued,SOLD Comeau Racing Enterprises, Inc. www.comeauracing.com We do only 924S, 944's, 968's all day, every day. |
SLED GUITARIST
I need to replace some bearings on the ta so I"m making plans. I sold my 944 na so i just have the two S. I am not opposed to replacing the TA with the whole tall 5th tranny a 5S, 7V. I wouldn't hurt my babies.
Thread Tools | |
Rate This Thread | |
