-   -   944 Problems (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/624074-944-problems.html)
JChristian00 08-10-2011 10:00 PM
944 Problems
So a couple of days ago i posted about how my 1984 944 overheated and the radiator hose to the reserve tank ruptured. Today i replaced the hose and the oil. I realized that the oil level was extremely low so i replenished that. So I starting it up today and I had even more issues! First off the oil pressure gauge is a zero and it would rev up to 3000 RPM is a few seconds after starting. What the heck is going on?
v2rocket_aka944 08-10-2011 10:54 PM
...is the gauge working?
John_AZ 08-11-2011 08:24 AM
I see you got your Porsche.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/613731-looking-buy-944-a.html
and then the break down:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/623169-1984-944-over-heating-issues.html
v2rocket_aka944 could be right-usually so.
Was the oil level extremely low when you bought the 944. Did you check?
To loose a quart or so of oil----unsure of how much volume "extremely low" means....
is not good.
Get some tools at Harbor Freight, compression tester and leak-down tester about $100 or less and do some tests.
Compression-leakdown test
Are your plugs oily? What color is your exhaust smoke?
Did you have an oily film in the coolant reservoir that looked like brown milkshake?
The compression/leak down test will confirm if the engine is damaged--heat warped head, rings, head gasket.
Remove the DME/fuel pump relay before testing. You do not want the injectors pushing gas in the cylinders.
GL
John
