-   -   Re-threading oil pan.. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/624399-re-threading-oil-pan.html)
AZ_porschekid 08-12-2011 08:36 PM
My turbo has a stripped oil drain plug. One of many fun things from the PO. I really can't afford another 100$ oil pan. Has any attempted to re-thread there's?
Also if anyone has a turbo oil pan that is cheap??:)
Rasta Monsta 08-12-2011 08:38 PM
Are they actually different? Perhaps the NA pan has a casting blank that can be drilled and threaded for whatever fittings you need?
John_AZ 08-12-2011 09:43 PM
Levi,
928 Motorsports - Porsche® Performance Parts - Oil Pan Drain Plug Repair Kit for the Porsche® 928, 944, and 951
Probably others.
GL
John
AA_Ezra 08-14-2011 09:48 AM
Napa, has a, and caries a Drain plug bolt that taps a new thread kinda like 1 over sized. I worry about the shavings tho. i guess you could flush some oil tho. orilleiy caries like a rubber type that expands in the drain plug. both run about 5$ or so i think worth a shot.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
