AZ_porschekid's Avatar
Re-threading oil pan..
My turbo has a stripped oil drain plug. One of many fun things from the PO. I really can't afford another 100$ oil pan. Has any attempted to re-thread there's?
Also if anyone has a turbo oil pan that is cheap??
85 928S; LSx conversion, 5 speed with LSD.
IRR... What IRR!
Old 08-12-2011, 08:36 PM
Toofah King Bad
Rasta Monsta's Avatar
Are they actually different? Perhaps the NA pan has a casting blank that can be drilled and threaded for whatever fittings you need?
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-12-2011, 08:38 PM
Proprietoristicly Refined
John_AZ's Avatar
Levi,
928 Motorsports - Porsche® Performance Parts - Oil Pan Drain Plug Repair Kit for the Porsche® 928, 944, and 951
Probably others.
GL
John
1988 924S 77K July 2017 ...+ 1987 924S 145K DD (+15K est. bad odometer)
Old 08-12-2011, 09:43 PM
Napa, has a, and caries a Drain plug bolt that taps a new thread kinda like 1 over sized. I worry about the shavings tho. i guess you could flush some oil tho. orilleiy caries like a rubber type that expands in the drain plug. both run about 5$ or so i think worth a shot.
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 08-14-2011, 09:48 AM
