Unhappy Oil Filter Removal
Has anyone figured out how to remove the oil filter without spilling the oil? It is not terribly bad but still annoys the heck out of me. I am using Malleys if that makes any difference.
1984 944 N/A Passadena Gold, No Sunroof
1971 Cuda 440-6, 4 Speed, The Last 440-6 Cuda built, Black
1971 Cuda 340, A/T, Rallye Red
1970 Cuda Ragtop, 383, 4 Speed, Triple Black
Old 08-14-2011, 03:57 AM
James Chimney
I stuff rags in from under neath and do it as quickly as possible, bad design in my opinion.
if some one has a better way please share.
Old 08-14-2011, 04:17 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Oil pan underneath, let her drip, finish the oil change job, spray GUNK on the affected area from above and below after you're done, hose it off from top and bottom and enjoy your car.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-14-2011, 06:40 AM
before you start to unscrew the filter, take a screwdriver and hammer it into the center of the filter. this will let air into the filter which will drain most of the oil from it...
it will still make a mess though.
Old 08-14-2011, 09:35 AM
Misunderstood User
I do all of the abpve.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-14-2011, 11:32 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
I disliked the inverted oil filter so much I finally did something about it. I installed a remote oil filter where the oil filter is hanging down properly and is lower in the chassis for better access from below. That took care of that silly design by the Porsche Guys.
I was for a long time puncturing the oil filter with a big screw driver until I found out that doing that allows allot of the debris from the pierced oil filter to drain back into the engine oil passages (not so good).
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 08-14-2011, 11:56 AM
