Rogue Tuning
Rogue_Ant's Avatar
Upcoming 944NA SD-Tune...
Just thought I would show a couple quick clips from today testing out our upcoming kit for the 944NA:
-Joshua
www.RogueTuning.com
Old 06-22-2011, 08:59 PM
Dawgz83948's Avatar
Ahh, good ole speed density mode. It would be nice to get rid of that annoying turbulence generator known as the air meter.
Old 06-23-2011, 07:59 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Please more information - and are these available for the turbo ?
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 06-23-2011, 01:03 PM
they already got 951 MAF and AFM version out
Old 06-23-2011, 01:32 PM
Rogue Tuning
Rogue_Ant's Avatar
Yep, removing the restrictive AFM will provide a good increase in power. On the 951, we typically see an average hp/tq increase of nearly 10% by removing the AFM without any other tuning changes. And, the 951 AFM is quite a bit larger than the 944NA one; the 944NA AFM is even more restrictive.
We do offer two Tuning solutions for the 944Turbo:
Rogue Tuning - Home
We use a different approach for the Turbo cars, due to the more dynamic nature of a turbocharged engine.
-Joshua
www.RogueTuning.com
Old 06-23-2011, 01:36 PM
Ok, so what does that Sd Stand for?
And in the second clip, how are you using that vacume valve/ idler. I hate trying to find the screws on those things when i gotta put them back in the chevy 3.1 v6 motor which is a garbage motor, good for me tho so i can replace the manifold gaskets when the water gets into the oil :P $$.
thanks for the freeware, dunno how to use it but i downloaded it anyways when i learn how
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 06-23-2011, 03:31 PM
Rogue Tuning
Rogue_Ant's Avatar
SD = Speed Density. Here is a good links for more reading:
theory-speed-density/
In short, I re-wrote the DME code to be a SD system, therefore using only a MAP & AIT sensor instead of the restrictive stock AFM.
-Joshua
www.RogueTuning.com
Old 06-23-2011, 03:38 PM
porscha
matty89's Avatar
sweet clip when is this available ?
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 06-24-2011, 12:22 PM
this is seriously cool.
Old 06-24-2011, 12:56 PM
Rogue Tuning
Rogue_Ant's Avatar
Soon, I expect the first production piece of the AFM elimination pipe to arrive next week!
I think so
-Joshua
www.RogueTuning.com
Old 06-24-2011, 02:34 PM
Marajit's Avatar
Interesting.
Will it work on an early (1984) engine, or is the DME an issue?
Peace to the Brave
1983, 1984, 1987 944 N/As
Old 06-26-2011, 05:47 PM
Rogue Tuning
Rogue_Ant's Avatar
My 944NA is an early 85. The only thing that will need changed is the DME - which is just a simple swap to the later DME.
-Joshua
www.RogueTuning.com
Old 06-26-2011, 06:12 PM
sasquatch's Avatar
This is what I am looking for. Eagerly awaiting information on availability and pricing for an 87 NA.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 06-28-2011, 08:08 AM
Catamax944's Avatar
+1 . Depending on price i am interested in this.
Catalin
'86 DD
Old 06-28-2011, 09:23 AM
Awesome
Andreas944's Avatar
Will this work on a S2?
Old 06-30-2011, 03:41 PM
Sign me up for one ! This with a chip and better exaust will give the NA just little more fun i suspect ?
Will also have to get a late DME, gonna try get one that is alrdy chipped
MSDS headers would also be nice with this one. Keep us updatet plz...
PS : I read about ur turbo NA engine, pretty cool ! Was that engine total stock when u did it ? What if you upgrade the pistons to turbo type and turbo fuel injektors would that help keep it running for years ?
Old 06-30-2011, 04:57 PM
Rogue Tuning
Rogue_Ant's Avatar
Pricing will be announced as I get closer to release.
The first release will be for the 8-valve cars. I'm looking incorporating the 16-valve cars in the near future - however I need a local tester...
The kit will include our own chipboard w/ software. The AFM is quite the restriction. On the turbo cars, which have a better flowing AFM, we see an average of ~9% increase in power across the board! I expect similar gains, if not better, on the 944NA.
The NA engine was a totally stock '87 short-block. If you upgrade the pistons/rods then there is really no difference between it and a normal turbo engine - it would last for a very long time.
-Joshua
www.RogueTuning.com
Old 06-30-2011, 05:14 PM
Rogue Tuning
Rogue_Ant's Avatar
Heya, just a quick update showing the prototype AFM elimination pipe
-Joshua
www.RogueTuning.com
Old 07-02-2011, 10:57 PM
Andrew Gawers' Dad
CHICKS's Avatar
Do you have a rough idea on pricing? Im in Colorado too, do you need another NA to test on? I know it's wishful thinking...
Old 07-03-2011, 04:35 AM
Marajit's Avatar
Joshua,
Will it accept a cone filter?
Peace to the Brave
Old 07-04-2011, 03:14 PM
