Send a message via AIM to Craig944[951]
'Kleen Wheels' - Any experience?
I have massive brake dust & am looking at buying some 'Kleen Wheels' to help eliminate the dust. Has anyone here tried them? What do you think about them?
AIM: Craig944T
E-Mail: craig944@bellsouth.net
It's, the, return of the price, the boss
This is real hardcore, Honda-Acura & Mitsubishi's soft
Sip cris', get chips, wrist gliss, I floss
Stick, shift, look sick up in that Turbo Po'sh
Old 03-18-2002, 09:25 AM
JGriff's Avatar
Re: 'Kleen Wheels' - Any experience?
I've never tried them, but I've heard that they are not a good idea, since they tend to keep the heat in, which is not good for braking performance and pad/rotor life (i.e. potential rotor warpage).
The best thing to do is resign yourself to the fact that you'll have to just wash the wheels every couple of days or so, or at least every week. It's a bummer, but I just look at it as a necessary evil.
Jim
Jim Griffin
JGriff@JGriff.com
1990 944 S2
JGriff.com
"Excite the senses, drive a Porsche!!"
Old 03-18-2002, 10:04 AM
RPM'S S2's Avatar
Generally a bad idea. Inhibits the flow of air (cooling) to your brakes. Wax your rims they will wash easier.
93 968 Amazon Green Metallic
89 944 S2 (Sold)
77 911 (R.I.P.)
Z-man's Avatar
If Kleen Wheels is a plastic shroud/plate that fits inside the wheel, then I suggest NOT using it. While it may keep the dust off your tires, it will also trap the heat in and around your disks, which can increase your changes of rotor wear and warping.
Best bet for brake dust: a good rag to the wheels every week or so...
-Zoltan.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Bob's944's Avatar
Send a message via AIM to Bob's944
Lightbulb
I agree with the no dust shields, and that waxing the wheels helps. The problem with most waxes is the heat build up on the rims makes it wear off too quickly. The brake dust and the wheels have different electrical charges so the metallic dust sticks well... and as you know most likely cause corrosion if left on, lil tiny examples of galvanic corrosion. There are a few different waxes out that claim to last weeks and neutralize the electrolisis effect. Sorry i can't think of a brand name off the top of my head, but look for some wheel wax next time you're at the part store.
Old 03-18-2002, 12:52 PM
Try Mintex brake pads
I drove 944
s from around 1986 to a few weeks ago; now drive a 968. My 944's always had brake dust problems until I switched to Mintex brake pads. Problem gone, and no squeal either.
John Etnier
Studio Dual
1993 968 Coupe, 6-speed, White/Tan with white wing, 17" 996 twists with Potenza S-03's, euro front lenses
Old 03-18-2002, 03:59 PM
