Jon C
jonjchris's Avatar
Clutch issue
Hi all! I have a 78' Porsche 924 that has not been driven for the past 3 months as I was doing some body repair in my spare time. I finished the re-assembly of the body today and was going to back it outside to wash and now my clutch seems to be frozen in the engaged position. When I try to start the car in gear with the clutch pedal pushed in, it lurches as the the pedal was not pressed. Sorry I cant give more details at the moment (I currently am working alone and have no one to help). I will post me details later, once I have a second set of hands. I last drove the car in May so it seems strange to me that it would freeze up this quickly. I have had no clutch issues previously and I have owned the vehicle for a year or so.
What steps should I try to release the clutch? Is this a common problem among 924's?
Any help would be appreciated.
Thanks!
78' Porsche 924
01' Chevy Monte Carlo SS
Old 08-23-2011, 02:58 PM
AZ_porschekid's Avatar
try starting it in neutral. then go into a gear. Is it stuck in gear??
85 928S; LSx conversion, 5 speed with LSD.
IRR... What IRR!
Old 08-23-2011, 03:41 PM
Toofah King Bad
Rasta Monsta's Avatar
The disc is frozen to the flywheel. . .not a 924 problem, an old neglected car problem. Try to start it in first then go off and off the gas with pedal depressed and it should break free.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-23-2011, 03:44 PM
Proprietoristicly Refined
John_AZ's Avatar
Have you checked your clutch cable?
John
1988 924S, 80K ..+ 1987 924S, 150K DD (+15K est. bad odo)
Old 08-23-2011, 03:48 PM
Jon C
jonjchris's Avatar
Done a bit more looking...
-The engine will start in neutral but when I go to put in in gear it grinds.
-The clutch cable does move and the shaft going into the bell housing also move but only a small amount. I assume this is normal.
78' Porsche 924
Old 08-23-2011, 04:02 PM
John_AZ's Avatar
Have you adjusted the clutch lever per Haynes page 144?
John
Old 08-23-2011, 04:18 PM
Jon C
jonjchris's Avatar
I got the clutch loose today. Thanks Rasta Monsta, your method work.
I know I need to replace my clutch in the near future, but I am going to put it off just a little bit longer as I have just put a lot of money and time in to the car
Thanks all for the help
78' Porsche 924
Old 08-24-2011, 08:34 PM
Toofah King Bad
I'd give it a little burn at this point. . .long slow start in 2nd with lots of slip.
Old 08-24-2011, 09:52 PM
