-   -   Power steering question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/626331-power-steering-question.html)
Ederd 08-23-2011 11:51 PM
So driving down the road i heard a couple of noises then the power steering went out. so i got home and got under the car and then saw my power steering pump hanging from under he car. The belt wasnt broken, but the strut was and the mounting bolts( front was sheered off and the rear bolt and sleeve were MIA). assuming everything went south bc the rear bolt came out and bounced merrily down the interstate, would it be ok to jb weld the front bolt back in? would jb weld be strong enough to hold it until i can buy a new pump in a few months, or is there a way to replace the front bolt?
http://forums.pelicanparts.com/uploa...1314168506.jpg
Jrboulder 08-24-2011 01:28 AM
Ed,
I can send you a pump in a couple weeks when i get back home.
My 84 had a Power rack but the whole system was shot so I never had power steering. It wasn't so bad.
Jackson
stogie25 08-24-2011 04:39 AM
I had the same thing happen this summer, except the front bracket on the balance shaft cover snapped off. I spent a VERY long weekend replacing it (and all the while you're in there's). It broke again a couple of weeks later. I replaced it again (not too bad to do this time as I was good at it) and found that the hole in the crank side power steering pulley had wallowed out and was what broke the bracket the second time. I also ended up replacing my harmonic balancer as the vibration had misshaped the woodruf key hole with the crank side pulley. Now everything has worked well for a few weeks. It has been a long summer.
John_AZ 08-24-2011 05:57 AM
Ederd,
The bolts can fail if the correct spacers are not installed properly.
Here is a good picture of parts needed (944online).
Pelican can get the bolt & spacers or you can possibly machine/improvise. Refer to a PET for part numbers.
http://forums.pelicanparts.com/uploa...1314190043.jpg
You need to be careful or you could ruin the PS mount --Lower balance shaft.
One other thing, there is an upgraded hose and fitting (item 7 in pic) for the reservoir to PS pump. Shorter. Pelican.
GL
John
Ederd 08-24-2011 10:04 AM
i went a head and ordered the adjusting strut, and a few bolts, spacer and a new belt. @ jackson i would appreciate anything you can do.
Pickpocket 08-29-2011 05:30 PM
Power steering is over rated. Just put a little more shoulder in it.;)
smokin_944 08-31-2011 06:12 AM
I dunno if I'd agree... Try running 235s on the front... For little 15 inch tires, mebbe 205s or 215s ok. Otherwise...not so much.
krystar 08-31-2011 07:40 AM
225's are fine as long as u max out negative camber. :) only issue comes if u try to parallel park
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
