"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
Porsche Crest What can this mean ???
Noticed today i had break fluid on the floor found it is coming from between the brake booster and the master cylinder what could this be? and is it expensive??
1986 Porsche 944 2.5
2004 Jeep Grand Cherokee Limited 4.7 H.O.
2000 Plymouth Neon
Old 08-21-2011, 09:18 PM
Well outside the car is better than inside the car i think. It usualy means its time for a new master cylinder or maybe rebuild you're current one. I either get a new one or install a known good used one after a good flush. Might rebuild it. not sure were to get the parts tho but im sure the info is on the board here somewere. I think its just a seal and maybe a new piston if the current pison checks out and there is no scoring. Either way there is nice one at my local junkyard just in case.
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 08-21-2011, 10:04 PM
Proprietoristicly Refined
John_AZ's Avatar
There is a "weep" hole in the MC near the booster.
Your MC seals are shot
A rebuild is only possible if the bore is not pitted or scared.
Usually a new MC is required
When was the last time you flushed the brake and clutch system?
Use a DOT 4 fluid.
Here is a picture of my "weep" hole
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-22-2011, 04:44 AM
mayPOR944's Avatar
brakes havent been flushed in a long time but the clutch has been bleed a couple times, My brake booster should be fine right?
2000 Plymouth Neon
Old 08-22-2011, 06:59 AM
John_AZ's Avatar
Booster OK
If bad you will begin to hear a hiss when the brake pedal is pushed and released.
Get ATE or Girling MC/kit --The one on your booster do not mix. I have seen a new universal MC that works on either.
Get new reservoir grommets 2
The reservoir is old caution--if you break the nipples, the reservoirs are expensive
GL
John
Old 08-22-2011, 07:39 AM
commdiver's Avatar
You might want to start looking at the soft line that supplies the clutch master cylinder with brake fluid before starting a 6 hr job. As the soft lines and plastic elbow that seal into the clutch master are high potentials for cracks, old brittle plastic and leak around the seal in or middle of soft line.
'83 944 ROW zermatt silver/black, sunroof & A/C factory deleted, houndstooth sport seats, 7Q - 220 LSD short fifth, F & R 23.3 MM 951 M030 suspension, 16" fuch's, manual windows, club sport mirrors, Blk/Wht gauges, rear seats & all sound deadening removed, 968 rear wing, fiberglass hood & 937 F bumper
Old 08-22-2011, 08:35 AM
John_AZ's Avatar
^ Good point.
You should also go under the dash and pull the rubber boots off the brake MC and clutch MC to check for leaking seals.
GL
John
Old 08-22-2011, 05:20 PM
mayPOR944's Avatar
yeah i will def check that out
2000 Plymouth Neon
Old 08-24-2011, 10:49 AM
