Motronic DME picture - how bad is this?
I have a badly running 944 1986 that seems to have one cylinder (one closest to firewall) not running well. Checked this and that, no effect.
Thought I could also check how my DME looks like. Opened the box, and this is what I got. Seems like someone has touched the solder joints at some point, but to me the brown areas and "bubbles" seem quite bad. Is this common that they look like this, or is this especially bad looking? If I buy a used replacement, what are my chances to get one that functions well? Anyone selling one with # 944.168.121.03 ?
Looks like old flux. Normal. From the pic everything looks fine bit that's like asking a dentist if you have any cavities over a faxed picture where you had your mouth closed. Lol. Either way, the brown is flux and it's used to help flow soulder. It should have been cleaned better from the factory so I suspect someone worked on this. It will not affect function.
82 928 s3&1/2 5 Speed LSD conversion 87 944 N/A 5 Speed (Under Construction) 81 931 (maybe for sale, well their all for sale lol) Always looking for a good deal. Hello, my name is Carl and im a Poschaholic |
Not sure that is flux. Production solder joints are completely clean of flux. If someone has tried to 'refresh' cold or cracked solder joint then there will be brown residue from the rosin flux.
Looks maybe like water damage to me. |
I've not opened up a new one, but that looks quite similar to a dead one I opened up from my parts car. That one had been leaked on for quite a while I reckon (a lot of water dripped out when I took it out).
If I ever get more pressing jobs done I was going to try to re-flow the solder on mine to see if it could be brought back from the dead. The dead DME I had meant the car wouldn't run at all though (wouldn't spark). I've not heard of a DME causing bad running on one cylinder (but I'm not that experienced in these cars - someone with more experience could chime in here). Don't know if that suggests it might not be the DME but hopefully someone can confirm or deny; would be a pain to buy a DME if you don't need one. Buying second hand from anywhere other than a company that gives you a guarantee is always going to be a bit of a risk. might be worth your while to buy one from somewhere local and insist you plug it into a car before buying (then at least if your problem turns out to be something else you have a known good DME).
1986 924S, Maraschino Red, Spax adjustable dampers, no air box lid. part way through interior swap. Lots of issues sorted, plenty more to do. 1986 924S, White, donor car, part way through disassembly. |
Thanks for replies so far. I think I should try to find another to test the car first, as suggested.
I put a close-up of the bubbles that don't seem normal to me.
Water damage is usually white. It would only look like rosin if rosin flux was used. It looks like an organic flux that wasn't cleaned. Im not saying its good and these other guys are wrong. Just telling what experience I gained from years of manufacturing. Either way, the bubles are not the problem. The copper underneath looks fine. They may be a symptom but not the problem.
Custom User Title
Your DME looks a lot like one I got out of an 88 NA that my son and I resuscitated. This isn't the greatest picture, but you can see similar damage:
![]() The car had sat outside in the rain for seven years (in Washington state) and had a thumb-sized hole in the battery tray - which drained directly down onto the DME. I was horrified and sure it was a goner, but as it turned out, the damage was superficial and the car runs just fine. Is your passenger side floor ever wet? Have you checked your battery tray for holes? Mine was actually still wet when I took it out of the car (last February). I let it dry for a few days, then cleaned it with circuit board cleaner, using a fluffy brush and compressed air. If your car runs well, except for one cylinder, how about:
With just one cylinder running badly, I wouldn't think the DME was the culprit. My understanding of how DME's work is that either they work or not - no halfway stuff.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
See the white lines surrounding the damage? That is what you look for with water damage. Surprised that one didn't catch fire.
SLED GUITARIST
Are you sure you didn't bust a valve spring on the non performing cylinder?
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2 1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan 1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Banned
Oh hell from what is visible in the pictures that isn't even that bad. I would wager an experience person with time a soldering iron and some 99% rubbing alcohol could clean that up and replace anything that shorted enough to break
Anything can be repaired. Love it I resemble that remark. And was being a little fesicious about the fire. Really my point was the first pic is probably not water damage.
82 928 s3&1/2 5 Speed LSD conversion 87 944 N/A 5 Speed (Under Construction) 81 931 (maybe for sale, well their all for sale lol) Always looking for a good deal. Hello, my name is Carl and im a Poschaholic Last edited by vdubr928; 06-28-2011 at 09:51 PM.. |
The flux residue is completely normal for all BOSCH Motronic v3.1 DMEs. The factory used a wave solder process where the entire bottom side of the assembled board is pass over a pool (wave shaped) of molten solder. The rosin flux is a "no-clean" type so they just leave the residue because a cleaning step would cost more and be purely cosmetic. When the rosin was fresh it was basically clear; it only turned brown once it fully oxidized and dried out.
All the fuel injectors are connected together and fired simultaneously. If only one cylinder is having issues the DME is not at fault. Last edited by Along4ride; 08-28-2011 at 07:44 AM.. |
Architect / Car Guy
Looking Forward to getting my First "car" Porsche 951 |
Banned
Toofah King Bad
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Architect / Car Guy
Yep i was wrong. But i've never heard of the springs failing
Toofah King Bad
They can break in extreme circumstances (high rev, high lift, too many miles) but are more likely to lose tension/seat pressure. . .this will give you float and charming little marks on your piston tops.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc Last edited by Rasta Monsta; 08-29-2011 at 12:30 PM.. |
Proprietoristicly Refined
Picture on Post 36 recent thread..(also Picture of johnkoawood in engine bay post 35).
Head scratcher... John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
