Fuel Injector Problem
I have an '83 944, looks like no signal to injectors, suspect computer. COuld it be something else that is easy to check? Thank you
Old 08-30-2011, 06:12 PM
Proprietoristicly Refined
John_AZ's Avatar
In the first post you said:
"I have a 1983 944. The car runs on ether, but doesn't run on gas."
Did you get the NOID lite to check the DME signal to the injectors?
Do you have the tach needle bounce 1/16th of an inch when cranking?
Does your fuel pump work when 12V directly applied?
You can send the DME computer to 944 Ecology to be tested. George is a member on Pelican.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-31-2011, 08:59 AM
Hey John, thanks for your help. I tested with the noid light, didn't light. I'm positive i have good fuel pressure, the tack bounces slightly when turning the power on and off, but no bounce during cranking.
Thanks again,
Charlie
Old 08-31-2011, 02:28 PM
John_AZ's Avatar
Looks more like it.
You might try to carefully --------resolder the DME, before you either send the DME to be tested or buy another.
Read a couple:
DME Repaired w/pics - Rennlist Discussion Forums
Early DME repair write-up with pics. - Rennlist Discussion Forums
Member TibetanT just posted a member on this forum does testing and repair. I do not know much more.
" On this forum is a member named ischmitz, his name is Ingo and he fixes ECU/DME Porsche units. This will save you some time and money."
You need to make sure you do not repeat the damage to the DME.
What do you think caused the failure?
Dead battery, cable short, corroded cables, high alternator output due to faulty regulator...
Ground your self or wear a wrist band ground when removing the DME.
Nothing to loose?
GL
John
Old 08-31-2011, 04:24 PM
John_AZ's Avatar
EDIT:
Have you tested the resistance on the Reference sensors?
Have you cleaned the reference sensor connections on the top rear of the engine?
Are the reference sensor gapped correctly?
Is your ignition switch connection cracked?
Ignition Switch Replacement
Speed and Reference Sensors - Checking, Replacement, and Adjustment
Ignition System Troubleshooting
Here is a recent no start post:
Mysterious Electrical Apocalypse
GL
John
Old 08-31-2011, 04:32 PM
