Bell housing hangup
Hey guys,
I'm well into the clutch job now. So far so good. Wasn't able to get the fork pin out so I removed all the PP bolts and the 4 Bell Housing bolts. Can't get the BH off, it seems to hanging on the driver's side near the top.I'm assuming there's one of those mounting sleeves up there.While looking at it, there is a sensor below the Speed Sensor bracket, it has a wire to the diagnostic plug up by the rear engine hoist ring. Does this sensor have to come out before removing the BH? I don't remember reading anything about it in my research and can't really tell by looking at it .Want to make sure before I start prying around up there. Don't want to do something stupid and break anything. TIA, Bruce
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
speed ref sensor has to come off before bellhousing can be removed.
after u get it off, cutout that part of the bellhousing where the speed red sensor has a hole. then u won't need to remove the sensor next time. |
spd and ref sensors are out, I'm referring to the diagnostic sensor ( I think).
Toofah King Bad
My recollection is that the extra sensor pokes through a hole in the BH. . .probably needs to come off.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Update
Got it out! I took the sensor in question out, but that was unnecessary. I had forgotten about the sleeve in the speed sensor bracket. Used a bent coathanger and pulled it up about 1-1/2 in. and that released the B/H
Banned
I got stuck on this too but I just did the clutch with the bh back as far as I could get it
