Boxster with a little trouble O2, Maf, Aos
Just bought a 99 Porsche Boxster...got a good deal and have been fixing minor things...but I need some help and thought this was a good medium for advice. I was getting rough idle and noticed the tube was leaking between the AOS and the crank case so I replaced it. The car now runs smoothly, but I just got 6 more codes. They are:
P0151 P1115 P1119 P1130 P1117 P1121 I have cleaned the MAF sensor...do you think I need a new AOS or CAT??? It appears the previous owner replaced the O2 sensors (all 4) with generic sensors because he was having O2 sensor check engine light problems also...we purchased it with this problem. Any help is greatly appreciated. |
Whoops. Wrong forum. Hope you get it fixed.
82 928 s3&1/2 5 Speed LSD conversion 87 944 N/A 5 Speed (Under Construction) 81 931 (maybe for sale, well their all for sale lol) Always looking for a good deal. Hello, my name is Carl and im a Poschaholic |
Here are what the code read:
P0151 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Signal Wire Short Circuit P1115 Oxygen Sensor Heating 1 After Catalytic Converter - Above Upper Limit P1117 Oxygen Sensor Heating 1 After Catalytic Converter - Below Lower Limit P1119 Oxygen Sensor Heating 2 Ahead of Catalytic Converter - Below Lower Limit P1121 Oxygen Sensor Heating 2 After Catalytic Converter - Below Lower Limit P1130 Oxygen Sensing Adaptation Area 2 (Cylinders 4 - 6) - Rich Threshold |
Still wrong forum. Try the boxster forum. Not many 944 guys going to recognize boxster codes.
Ours might throw an oil pressure light here and there but without a hammer we couldn't tell you.
| Tags |
| aos, boxster, maf, o2 sensor |
