overkill's Avatar
Send a message via AIM to overkill
I think my CLUTCH is on it's way OUT---->
Well, before you start snickering about me posting a CLUTCH issue,... I had searched the archives and read what I found, now,...
Basically, I noticed it when I shifted to 2nd and gased it,... it felt like the car had let go for a second then pushed forward a bit, it did that a couple of times in almost a very smooth rocking motion? Also, I noticed the the RPM's were a bit higher then it was suppose to be for whatever speed I was doing. The car felt like it lost its pickup? I had really noticed it when I floor it every changing of a gear. Usually I see the front of the car pick up a bit due to the torque, nows it doesnt picked up as much and when I gas it after changing gears it is like extra smooth feeling. I tried to explain it the best I can. Later on Im gong to do what lordgrommit had told somone else to do. Put the car in 3rd gear and apply brakes and then let go of clutch. If clutch is good car should die fast. Also, someone said somthing about an inspection plate on transaxle and powertube, put my hand inside feel for driveaxle i think them move it back forth if it clankes then clutch is bad?
Well, if my clutch is bad, I will need a new one Teasing, I should go a centerforce? I heard they were good? What about sachs? PELPARTS has a complete kit with everything for like $701 for my car, would it be best to replace all of it with new parts? The thing is that full kits come with sachs! Whats up with sachs? If I get the centerforce kit what doe that usually come with? I know it does come with every thing the sachs kit does from PELPARTS. I dont know what do you guyz think?
{1987}944S - (SOLD).
Old 03-15-2002, 10:07 AM
Obin Robinson's Avatar
just to tell you.... i got a like-new clutch from rennlist. after everything it was about $350 for ALL THE PARTS I NEEDED. i'm 100% satisfied with it.
labor was in the $650 area.
good luck!
obin
"Resale value": the phrase most often uttered by people who are afraid to admit they can't afford their car.
Old 03-15-2002, 11:36 AM
overkill's Avatar
I dont want to use like-new stuff,... I just want to know if I should replace all this stuff for my car, i have an 87 944S with like 75,000 miles on it.
This is the pelicanparts full clutch kit. Is this necessary? Will I be fine just buying a new clutch?
New 944 Pressure Plate
New 944 Clutch Disc
New 944 Throw-out Bearing
9 Flywheel Bolts
Pilot Bearing
2 Release Lever Shaft Bearings
Slave Clutch Cylinder
Flywheel Seal
Throw-Out Bearing Guide Tube
Clutch Alignment Tool
Clutch Master Cylinder
Old 03-16-2002, 07:05 AM
Thumbs up
other than the clutch master and slave cylinder (mine were absolutely fine and didn't need replacement)... those are EXACTLY the parts i got. the pelican kit has everything you will need.
good luck!
obin
Old 03-16-2002, 07:24 AM
overkill's Avatar
OK cool!!! Im not going to get the kit though, I want to get the centerforce clutch and Ill but all the other stuff sepretly. Also, I thought I would do the synchros in the tranny seeing that it has to come out....
Old 03-16-2002, 12:14 PM
AKA J BERK on Rennlist
jsb944's Avatar
Overkill
Just curious....what part of NJ? Who does your P car work, or do you do it all yourself?
Joe
Joe
Current: 2014 Cayenne S
Gone but missed:
2003 996 C4S; 1991 944 S2; 1984 944 NA
Old 03-16-2002, 02:50 PM
overkill's Avatar
I live in Willingboro NJ, and I do all the work myself atleast will try too, but I have several people to back me up if I fail so a P-mechanic is a last resort. I also commute to new brunswick and east brunswick alot.
Old 03-16-2002, 04:15 PM
