-   -   How do I access the oil/clock and A/C switch panel? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/628975-how-do-i-access-oil-clock-c-switch-panel.html)
924Sman 09-09-2011 09:13 AM
This pertains to 924s and early 944...I need to replace the switch and do not have any idea how to take the console apart to get behind the gauge pod so I can disconnect the fan switch wiring etc. Anyone care to help me out? Thanks in advance...
Grandad#3 09-09-2011 10:44 PM
Whenever you run into problems, always turn to Clark's garage.com for maintenance help.
Early 944 Dash Replacement
Cheers,
Larry
ecostellodo 09-11-2011 02:59 PM
I think he is referring to the center console.
vdubr928 09-11-2011 03:07 PM
Yes but the instructions for pulling the consoles are there because it has to come out first.
It comes out pretty easy once you remove the shifted panel screws then you can see what's holding it but you have to pull the knobs and such. Use the instructions. They are accurate.
ecostellodo 09-11-2011 03:45 PM
Your right, I just didn't jump all the way down to step 9. Although I can't remember if I removed only the upper two screws or all four.
http://i270.photobucket.com/albums/j.../iphone015.jpg
http://i270.photobucket.com/albums/j.../iphone007.jpg
924Sman 09-11-2011 03:55 PM
Thanks for the replies!....I did remove the 2 screws and the panel did not budge, I did not however try to lightly pry it off but perhaps another attempt is in order. Do I need to remove the panel below first to remove the upper panel, if so then that must be why it would not budge?
Jrboulder 09-11-2011 04:00 PM
you have a PM
Call me and I will talk you through removal
Jackson
