-   -   CV Axel for Automatic (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/629087-cv-axel-automatic.html)
djnolan 09-10-2011 04:27 AM
CV Axle for Automatic
Can anyone advise if the CV axle assembly for an 85.5 automatic are the same part as the CV for the 5 speed? I have not been able to find a part listing specifically for the automatic CV axle assembly.
Situation is my 85.5 automatic is starting to clack. If I can't find the replacement CV axle, I was considering reversing the 2 axles and adding some new grease. Since this is such a messy job I doubt I will find any shop willing to do it. Can I just add grease if the boots are not cracked when I reverse them, or do I have to disassemble and clean the joints before re-greasing?
Thanks!
RC924 09-10-2011 09:17 AM
Individual A/T axle shafts are different lengths and different again to M/T shafts. AFAIK CVs are the same.
Sure you`ll find a shop willing to do the work if you`re willing to pay their hourly rate. Just a boy`s job and an easy DIY task, even for a novice.
Try flipping EACH shaft end for end. No need to dismantle to clean, after pulling back the boots, clean out old grease with rags, wash clean in gas & blow out with air before repacking with new grease of appropriate grade. Procedure should be detailed in the manual or Clark`s Garage.
djnolan 09-10-2011 01:49 PM
Since they are different length I will flip the clacking one and try it out. Thanks! Will let you know how this works out!
Thanks Stuttgart!
