-   -   924, 77 only starts when by-passing feul pump (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/629492-924-77-only-starts-when-passing-feul-pump.html)
Raa 09-12-2011 05:03 PM
we changed the relay... fuse looked good....turns over well... will only start when by- passing feul pump with a battery....
could it be a wire, and which wire could it be...or....what could it be?
when we undo the battery, the car stops.
Raa
Raa 09-12-2011 05:36 PM
everythings alright.
we found a fuse on the air conditioner relay which was blown. the haynes manual said to check the fuse on the air sensor relay to trouble shoot.
...cnanged the fuse and she parted.
Raa
