WANTED : 944 S2 cabrio right side main bow
I own an 89 944 S2 Cabrio and broke the passenger side bow while trying to remove the top using the automatic system.
Any help finding a replacement part would be appreciated.
Old 09-13-2011, 04:54 AM
Dawgz83948's Avatar
$600 ea + Shipping to Canada.
Old 09-13-2011, 08:48 AM
There are very few cars worth significantly more in parts than as a whole. Some 944's are them
Jackson
Old 09-13-2011, 12:32 PM
racer951y's Avatar
Send a message via AIM to racer951y
Jackson
A truer statement has never been said.
and on a side note I see your Cab is the same color as mine what color is the interior and the top?
'82 928
'86 951(RIP)
'90 944 S2 Cab (RIP)
'92 911 C2
Old 09-13-2011, 01:03 PM
flash968's Avatar
that's an incredibly good price. the last time i saw them they were $1000 each
Old 09-13-2011, 01:46 PM
It's a linen interior with the 8 speaker package and black top. Supposedly there are very few Cabs in this color.
134k on the clock and none of the cosmetics have been touched but all of the mechanicals have been gone through at least once.
Jackson
Old 09-13-2011, 01:54 PM
racer951y's Avatar
On topic: I had mine welded but I also do not have the motors hooked up.
Off Topic:
Jackson
Mine has a burgundy top and interior with the 10 speaker radio and 170k on the chassis 140k on the engine (not the engine that came with the car the original owners drove though a puddle and hydro-locked the engine).
Here is a post I did with my car 944 color options..Any pics of rare colors?
'82 928
'86 951(RIP)
'92 911 C2
Old 09-13-2011, 02:44 PM
Dawgz83948's Avatar
What did the welding of the bows cost. Last I checked on EBAY it was like $1k.
Old 09-13-2011, 02:55 PM
racer951y's Avatar
$100 had it done at a local welding shop
'82 928
'86 951(RIP)
'92 911 C2
Old 09-13-2011, 03:27 PM
flash968's Avatar
done right, with a reinforcing plate added, welding can work, in manual mode. done wrong, it will cost you a top.
i don't know of anybody who has successfully done it in power mode for very long. it always ends up snapping again, and then taking the top with it.
crappy design. i've been in manual mode for years just to avoid this problem.
Old 09-13-2011, 05:36 PM
racer951y's Avatar
It has been three years for mine and no problems yet and I use the top every day (but for rain and snow/ice days). Of course it is in manual mode never liked the power mode anyway.
'82 928
'86 951(RIP)
'92 911 C2
Old 09-13-2011, 05:43 PM
This doesn't sound right. A reinforcing plate sounds like a hack.
A competent aluminium welder should be able to weld these so that they are stronger than original. But you must be very careful to use a skilled person. The pieces needs to be very strongly fastened in a jig during the process, otherwise there will be terrible shrinkage. So again, be very selective about who you entrust this work to, and there should be no problem.
I paid the equivalent of $140 to have it done locally - the result is as far as I can judge very good. I also helicoiled one of the M10 threads.
The Porsche power hood mechanism is another issue, it really seems to be a disaster waiting to happen.
Old 09-14-2011, 12:16 AM
may I ask what are those and what they do?
white 81 924
Old 09-14-2011, 01:08 AM
flash968's Avatar
you would think so, but the material is very soft and porous. a weld by itself still leaves the piece weak. the problem is that the weld is not what fails, but rather the material right next to it, which was just as weak as where it broke the first time.
but, if you add a plate to the weld repair, thus spreading the load out over a larger area, you get something that can withstand normal use.
still though, in power mode they tend to break again. the dual motor design is indeed a disaster waiting to happen.
Old 09-14-2011, 11:40 AM
mhr mhr is offline
they are the main bows for the convertible top in an s2 cab.
BTW I converted mine to manual when I got it. You really have to get out of the car either way to put on the cover so manual is just faster and easier. Also is a good practice to help the window fold nicely to minimize wrinkles and hazing the plastic.
Old 09-14-2011, 07:23 PM
flash968's Avatar
yeah - i was pretty bummed when i got my car
i thought "oh cool. finally a power top" (having come from british stuff that was all manual)
then i went to put it down and found out that you had to get into the console to get the handles out, then stop it part way down to put a towel or something down on the window to prevent it from scratching, then you had to get out and put on the boot cover to prevent the headliner from getting all filled up with the crap in the air. the entire process takes a few minutes, and is not what i had hoped for. heck, even a ratty old 80's mustang has a top that goes down quickly at the touch of a button. what was porsche thinking when they allowed ASC to do that?
Old 09-14-2011, 07:55 PM
Was it ASC or Porsche who came up with the mechanical setup? IIRC there are a lot of 911 part numbers in the cab top mechanism (motors and transmission).
How does it compare to the power cab top that was available on the 86 and up 911's?
Jackson
Old 09-14-2011, 09:06 PM
flash968's Avatar
definitely ASC. they set up shop over there to do it. i've spoken to the guys who did it. interestingly, the design actually originated at BMW
Old 09-14-2011, 09:42 PM
