Knocking noise
What is the sound when I shift the gears in my 944? It just started doing it. As soon as the gear shifts it makes a knocking noise...
Does your shifter have play in it?
I mean, a little.. But nO more than it did before
rubber centered clutch? CV joints loose? Shock bolts at rear? rear sway bar links/bushings?
Probably something pretty easy...clutch is a job though. |
If it's the clutch, replace it with a conventional spring centered clutch plate. The rubber centered ones are junk. Do you see the shifter moving around when you hear the noise?
It sounds like it's coming from the transmission. And it started making the noise after I went 155.....
| All times are GMT -8. The time now is 02:52 PM. |
