Poll: 84-944 that just dies after starting
Poll Options
84-944 starts then stops in about two seconeds
I have a 944 than I drive about once a week or so. For the last couple of months the car would die after starting three or four times and then be ok. Last night I had to have it towed as I only got a few blocks from my house and it stopped. What it is doing now is starting, running about two seconds and then dying. When you give it gas to try to go it dies. I have recently replaced both sensors (bought from you guys) and the DME relay is also new. Any idea what is going on here? I don't remember replacing the fuel filter for a long time...any chance that cheap fix would work?
Thanks;
tjbick@gmail.com
Old 09-21-2011, 09:00 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Could be the fuel filter or the fuel pump - DME relay if when it goes out it usually stays out with no start. Fuel Pumps some times go out erratically like that, and sometimes they will just quit. Have also seen symptoms like that when the wiring to the Throttle Position Sensor is bad/loose/corroded. Could also be the TPS it's self...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 09-21-2011, 11:39 PM
or could be just fuel pump relay.. it gives the pressure after turning the key and then when cranking and get started it stops the fuel pump, there is pressure and fuel on lines what she eats at those 2 seconds..
white 81 924
Old 09-22-2011, 01:02 AM
I don't think it is the DME relay because I have two of them and it does it with both of them. I might change the fuel filter as it is very old.
Old 09-22-2011, 07:39 AM
