power window
How can I raise up the power window on 83 944 and bypass switch?. Do I ground wire the motor and touch the lead on the window motor?
Old 09-21-2011, 05:06 PM
carsonmx114's Avatar
The switch is probably a reversal rest at ground system. There is most likely 5 wires there. 1 is a ground that going to both motor wires when the switch is at rest. 1 is 12v switched and the other 2 go the motor. When you activate the switch in either direction the ground is taken off one wire and replaced with power. In short figure out which 2 wires go to the motor, then apply voltage to one and ground to the other, to reverse the direction of the window reverse the polarity of the wires. don't try this with the switch plugged in because both wires will be grounded!
86' 951
k26/27 hybrid turbo
01' audi s4
98' TDI jetta
96' 933tt AWD LS1
Old 09-21-2011, 05:45 PM
window power up
Thanks carsonmx114 I will give it a try appreciate the get back
Old 09-21-2011, 06:47 PM
