-   -   removing distributor rotor (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/631118-removing-distributor-rotor.html)
rmcdonnell 09-22-2011 03:54 PM
Mine seems to be seized in place, yup the little torx screw is out. Looks like a plastic rotor arm on a brass collar on the camshaft. Is there a keyway, or spline and do I have to wreck the old one to get it off, or is there a cunning trick to it..?
cheers
Rissole
nynor 09-22-2011 04:06 PM
i've had to wreck a couple of them. then i had to use vise grips (the horror!!!) to get the brass collar off of the camshaft.
when you put it back together, use a little anti-seize on the inside of the rotor.
rmcdonnell 09-26-2011 04:10 AM
Thanks Nynor.
Guess that means a replacement is required. :(
Or live with it.
I found I could still remove the cam cover so maybe next time I'm in there...
cheers
Russell
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
