rmcdonnell's Avatar
removing distributor rotor
Mine seems to be seized in place, yup the little torx screw is out. Looks like a plastic rotor arm on a brass collar on the camshaft. Is there a keyway, or spline and do I have to wreck the old one to get it off, or is there a cunning trick to it..?
cheers
Rissole
944 Alpine White '89 2.7L
Old 09-22-2011, 03:54 PM
winter-hater club member
nynor's Avatar
i've had to wreck a couple of them. then i had to use vise grips (the horror!!!) to get the brass collar off of the camshaft.
when you put it back together, use a little anti-seize on the inside of the rotor.
"COOL PRIUS!" - Nobody Ever
Old 09-22-2011, 04:06 PM
rmcdonnell's Avatar
Thanks Nynor.
Guess that means a replacement is required.
Or live with it.
I found I could still remove the cam cover so maybe next time I'm in there...
cheers
Russell
Old 09-26-2011, 04:10 AM
