Value of Fuch Wheels
I was curious what would the value be of 951 fuch wheels. They have tires that are almost brand new on them.
What would they be worth? |
What size and width? 911 Wheels?
They are the 944 Turbo ones. They are 7" front and 8" rears
Are they 15" or 16" and I don't recall them coming from the factory on 944 turbos. The early offset turbo wheels I believe had the phone dials. Is the oustide lip polished and inside painted black and are they in good shape with no curb rash? There should be a part number inside.
Some 86 turbo's came with fuchs as options. 99% sure fuchs are only early offset and are 16" if they actually came original on his turbo.
Eric
If in good conditions I would say about $1500 for the wheels alone.
Eric |
Like $800 if you want them to sell. $1400 if you like fishing.
Jackson |
Non Compos Mentis
The 16 x 8 rears from the 1986 Turbo are highly prized by the 911 crowd, as they are the only 8" Fuchs that will fit the front of an early-offset 911.
Paired with the equally hard-to-find 16 x 9 in the rear is considered about the most desirable wheel combo. These values may be dropping, as the selection of high-performance tires in 16" sizes is getting pretty sparse. Very cool wheels, but not worth much if there are no tires available for them. I'd probably sell them fairly soon. |
