924 relay with fuse mounted on it and no feul arriving to injectors
anyone know where i can get 924, 1977, relays in monteal , quebec, canada. the relay i am looking for is just to the right of the feul pump relay and has a red fuse on it. the fuse keeps blowing out. coould it actually be because of the relay. relay...SHO 477 906 059 ----- 89 6444 000 ... made in Hungary 12 volts max, 13 A ind.--- 6 pin ---+++ - a 16 amp fuse is encased on top of it.
There is no feul coming out of the injectors. the feul pump relay is good. |
Not certain, but probably the rear defrost relay. Perhaps the wiring for that is loose and grounding... or the hatch struts are incorrect (current is passed through them).
As for the fuel injector delivery problem... numerous possible causes, you'll need to step through the whole diagnosis... |
| All times are GMT -8. The time now is 09:05 AM. |
