Slight Vibration - Flywheel Issue?
As I've been putting my 85.5 through its paces following a total engine reseal - I've begun to notice a few things. Among these is a slight, rythmic vibration, which I can both hear and feel through the gearshift knob. I notice this mostly in the range of 2500 rpm.
So I'm thinking...that this might be either a slightly out of balance flywheel, or a torque tube issue, possibly a tranny issue, and maybe something as simple as the P.S. pump pully at the end of the crank...which does seem to rotate slightly off center - but its mass does not seem large enough that it should cause anything noticeable.
My first thought was maybe a balance shaft issue....but I don't think this is it.
When I rescued this car several years ago and pulled the engine, I'd noticed that the P.O. had replaced the clutch as he mentioned, but he'd also left off the inspection cover and thus there was a slight amount of surface rust on the flywheel, which I very gently sanded with some 600 grit paper. Would this have been enough to throw the flywheel out of balance?
I admit that I'd cheaped-out by not having the flywheel resurfaced and rebalanced - so maybe this is the culprit. If so...can anyone advise how much risk this might pose to the engine bearings? I'd hate to have an issue like this slowly wreck an otherwise very smooth engine.
Old 10-14-2011, 05:25 AM
I have a slight vibration also, but I am almost 100% sure mine is because of the TT bearings, they are making a terrible racket Haven't had the time to fix it! I think if your TT was going bad you would hear a slight noise.
My cars :
1984 Porsche 944
1985 Nissan Pickup SBC swap
2005 Chevy cobalt
Old 10-14-2011, 05:50 AM
Proprietoristicly Refined
John_AZ's Avatar
If you are certain it is not the balance shafts or pullys, bad engine mounts at 1100rpm, and the cam belt matches the timing marks perfectly (not off 1/2 tooth) ,,the sanding would not make a difference.
You can check the flywheel balance by revving the engine at certain RPMs in the garage in NEUTRAL.
If you get the vibration standing still it will eliminate the TT torque tube bearings,
If you want to check the torque tube for vibration, disconnect the rear transaxle coupler--slide it back. Start the car and shift to where you have felt the vibration.
If you feel the vibration (or noise) in the shift lever now, it is probably the TT bearings.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-14-2011, 05:56 AM
White and Nerdy
Tervuren's Avatar
GL
John
Actually, wouldn't you need to rev it with the clutch pedal in? Simply in neutral the torque tube is still spinning, and the input shaft of the gearbox is also spinning.
Shadilay.
Old 10-14-2011, 06:41 AM
John_AZ's Avatar
Thanks,
You are right, In NEUTRAL with the clutch pedal pressed in.
John
Old 10-14-2011, 06:46 AM
Wouldn't clutch pressed in while trans in gear while car is stationary ensure no TT spinning?
Old 10-14-2011, 10:27 AM
John_AZ's Avatar
Yes, Good point.
Neutral would be safer----when stationary.
I can mentally see someone frustrated and tired,
Start the engine in the garage,
Put car in gear, Press in the clutch pedal,
When finished while the engine is running,
Release the clutch before turning the engine off....
John
Old 10-14-2011, 12:25 PM
Yes, Good point.
John
Ha, sounds like something I'd do!
Old 10-14-2011, 01:07 PM
