How to get more hp?
Hey guys. I own a 1988 Porsche 944 Turbo S. I love the car the car to death. And she is so quick! But, just like any other guy, I want more speed. So, what is the most cost effective way to increase the hp. I looked at a MAF unit that Lindsey racing had but it was like 800 bucks. Thanks guys
Old 10-17-2011, 03:11 PM
racer's Avatar
While not at all the answer you want.. spending money on driving skills is a better investment than a chip/intake etc.
Past:
2000 Boxster 2.7, 1987 944
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-17-2011, 03:39 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
To get any appreciable increase in H.P. is a high dollar venture.
1.) A Chevy V8 will work
2.); Rebuild with turbo parts and a turbo system.
3.) Larger Valves, big cam, MAF system, adjustable pressure regulator, Larger
Injectors, piggy back controller system, custom chips - may add 25 to 30 h.p.
Porsche designed the motor to get the most H.P. as possible, with reliability, from the start so it's hard to squeeze any more out of it without major mods.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-17-2011, 04:09 PM
I can push her to the limit. I just want the limit to be practically limitless eventually
And I also already have had the turbo rebuilt. But yes, I'm thinking a MAF unit and then prob a chip.
Old 10-17-2011, 04:20 PM
ernie9944's Avatar
951 are really not my bag even though I had the chance to drive a couple ,in fact one was an 89 S with a (vitesse maf) & close to 400 HP.Almost bougth that car but after driving her around for a couple of days in different situation I decided not to.The reason being that, how often are you gone to be able to use all that HP and the speed it generate, & how reliable are they on a long run when you reach that point. Your car rigth now has 247 HP @ 6000 RPM,it will do 0-60 in 5.5 sec & if in tip top shape mechanically & suspension wise should be able to see 162 MPH + on the speedo (not bad for a 28 yrs old car).So ask yourself this simple question,does it really worth losing all that reliability for let say 20/30 more MPH.But this is one own choice & it's your car.For more HP maybe you can talk to those guys http://www.linsayracing.com (Scroll down).Btw there is a few 951 owners here which are very knowledgeable & can give you the pro & con on modifying your motor I'm sure they will chip in.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 10-17-2011, 05:20 PM
Non Compos Mentis
More speed, or more acceleration?
If top end is secondary, swapping to a shorter final drive in the tranny will really wake things up.
Old 10-17-2011, 05:26 PM
I definitely want more acceleration. And Ernie- I see where your coming from. I have been up to 160mph(which was stupid) in my car.
Old 10-17-2011, 06:11 PM
Custom User Title
mikepellegrini's Avatar
The only reason people stoop to put V-8's in 944's is because they don't really understand 944 engines. I guess I am a purist. But putting any Detroit iron in a 944 is a travesty... Kinda makes me wanna gag.
My son built his 951 - he's added a whole lot of mods.
His first round:
  • Lindsey Manual Boost Controller
  • Lindsey 3" Exhaust - no cat, no muffler
  • 3 Bar FPR
  • Aftermarket atmosphereic BOV
  • Open Tial 38mm Wastegate (Dumps to atmosphere)
  • 951Max chips
He dynoed the car with those mods and it came out at about 250 RWHP with just under 300 FtLbs of RWT - figuring the cars stock are probably around 180 RWHP, that's about a 70HP increase to the wheels. Not bad. I'm not sure how much boost he was running in the dyno run.
It was pretty awesome. Very quick.
He did a second round maybe a year later, adding:
  • LR Super 65 turbo
  • LR Stage 2 MAF
  • 75# injectors
  • Innovate LC-1 Wideband O2 sensor and digital AFM Gauge
Running 17 PSI, the car is just plain scary. We haven't dynoed it, but we're guessing it's in the 400 RWHP range.
In terms of money, I'm not really sure how much he has in it. But it's really not that much.
If you wanna go really nuts, talk to Nize and ask him about the Wolf3D engine management system he uses in his 951...
83 944 NA - Black on black
86 951 - Red
97 Ford Expedition
He who hesitates is lost.
Old 10-17-2011, 06:40 PM
Ditch the heavy electric seats, the old spare (which probably wont hold air), bin the AC, smaller battery, and pull out a few more bits to get her lighter. A lighter car is a more responsive car and its cheep to do.
86 944 NA (Since new!)
2002 Evo 7RS (track pig)
2009 Jeep Wrangler Unlimited (tow car)
2007 Subaru Legacy Wagon (Wife wagon)
Old 10-17-2011, 06:49 PM
ernie9944's Avatar
There is a reason I'm for stock reliability (with less HP) instead of (mega HP).A friend of mind has a perfectly stock 86-951 which he enjoy pleasure driving & tracking.He start fooling around with it (wanted more boost),and for the last two months it's been nothing but headache.First the head gasket went nuke & then this & that.So instead of enjoying the car, now he is stuck working on it & spending money.Doing 160 MPH with those car for short period of time (if they are in tip top shape)is not that stupid ,they were made to be driven at very higth speed but anything over that is pushing your luck.
Old 10-17-2011, 07:00 PM
J1NX3D's Avatar
soooo.... then what condition was your friends car in before he upped the boost? I think you're taking a calculated risk with a 25 yr old 951 that hasn't been sensibly rebuilt before looking for power.
OP, make sure your engine is healthy first before starting on power mods!!
'86 944S3 conversion
Old 10-17-2011, 08:07 PM
Aussie944S's Avatar
got told some good advice by an old tuner "you change one it affects seven others"
Old 10-17-2011, 10:38 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Just freshened up my 951S engine, went to a k27/6 turbo (stock is a k26/8), Tial 38 dual port w/g), Vitesse MAF and a few other upgrades...couldn't be happier with the end result. Haven't had it on a dyno yet, as I'm still waiting on the piggyback fuel controller and the electronic boost controller. Very smooth idle, rapid acceleration, and with the smaller "hotside" quickspool turbo, boosting much sooner than stock and carrying boost all the way to redline, not dropping off at 5800 like stock.
The engine I am building now will have the head "O-ringed", extrude honed intake, and a few other refinements to better utilize the power developed by the larger turbo. BUT, this all does come at a co$t, and far more if you don't have access to shop facilities and support (wholesale parts, a machinist, etc).
The upgrades I just did came in well under $3000, with the turbo ($500), Tial ($185 w/adapters), Greddy Profec B Spec 2 ($225) and Innovate Wideband O2 sensor w/XD-16 ($275) being the high ticket items.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 10-17-2011, 10:58 PM
That Guy
Techno Duck's Avatar
300whp is easy to do, gut the cat and get chips that allow you to run 15-16psi. MAF is not needed, but is a well worthwhile mod do to increased throttle response. That alone will get you close to 300whp.
Another 'must do' mod is replacing the wastegate (stock tends to open too early) which kills spool and peak power.
Once you start modding though, every weak point (from old parts) in the car will start to show itself.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-18-2011, 07:44 AM
Dawgz83948's Avatar
You kinda have that backwards. We put V8's in them because we do understand the 944 engine.
Old 10-18-2011, 10:05 AM
smokin_944's Avatar
Let's put it this way, you can push Detroit steel hard (SBC) and maintain reliability. Turbos are more finicky and past a point they go boom! Ernie has it right when he says maintain a fairly stock 951 engine, few problems. Go big with it, reliability COULD become an issue. Just sayin...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 10-18-2011, 10:26 AM
Vey, yes mister President
cockerpunk's Avatar
951 MAXX chipset or authority stage 2 makes the most sense.
my car is a 86, with 4 inch exaust and testpipe, and authority 2, and it pulls way hard. never driven a turbo S but im betting its quicker then a stock one right now, by a fair margin. im not looking for mroe power anymore, im looking for quicker spool ups. have the lindesy boost enhencer, thinking i need to go M-tune next.
Old 10-18-2011, 10:34 AM
That Guy
And lets for forget, if your putting in any LS series motor its Detroit aluminum.
I think i understand these motors pretty well. The LSx has many advantages.. part availability / cost, reliable 350+whp (you are starting to push it at 300whp on the stock engine), flat power band, less oiling issues and replacement engines will run you around $1500 for a complete drop in used LS1. Also you have many engine choices to pick from depending on the power you are looking for.. LS1, LS2, LS3, LS6 and if your crazy LS7. 430bhp out of a stock LS3.. yea try and get that power out of a turbo and keep it reliable with a usable powerband.
Jon
Old 10-18-2011, 10:35 AM
Thanks guys
Old 10-19-2011, 01:07 AM
