LanceKTM950's Avatar
968 headlights "winking"
ARGH! Now that it's dark when I drive I need the headlights but last weekend I put them on and both headlights rose up but the passenger side fell halfway back down, now when I shut the lights off it the driver's side goes down but the pass. side comes up, when I turn the lights on the driver's side comes up but the passenger side goes half way down....
Is there an easy fix?
TIA,
Lance
Old 10-18-2011, 02:37 PM
968 GUY's Avatar
You may have a problem with the linkage from the motor to the light has come loose. Raise the headlight manually and check.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 10-20-2011, 08:57 AM
