Is Amsoil syn gear oil the right stuff to use in the tranny of my 84 944. If so any opinions or experiences with it?
I used Swepco,works good.
Texas hosts the 928 Owner’s Club OCIC in 2009 www.928ocicdfw09.com 1980 928 5 speed and a few mods.......... ![]() 928 OC member PCA member |
While we're on the subject - can anyone give me some links to tech articles on transmission flushing / maintenance?
Thanks.
Jake 1983 Euro 944 (Mine) 2000 BMW 323i (Hers) 1997 Sentra (unclaimed!) |
Ummm, i dont have any links for you but according to the haynes manual,...
1) Lift car 2) Get under car 3) Remove 17mm hex head drain plug thingy 4) Catch oil in pan 5) Do not get oil in face 6) Put 17mm hex head drain plug thingy back on 7) ... tight 8) Remove 17mm hex head fill plug thingy 9) Put in new oil 10) ... good luck 11) Check oil level 12) Repeat 9 - 11 until full 13) Put 17mm hex head fill plug thingy back on 14) Lower car 15) Clean up 16) Drive car 17) ... slowly at first Then your done! Its that easy! Even a dumb arse like me can do it!
{1987}944S - (SOLD). |
I would seriously consider making sure I could get the fill plug out before draining the tranny.
Great guys - thanks for the hints (overkill - just my level of instruction!)
really! HA HA HA, good! Me too!
least common denominator
I have a 1984 also and I am getting ready to do the trany fluid...
Previous posts strongly recommend making sure 17mm FILL plug is not seized before draining. I LOVE synthetic oil! I have run nothing but Mobil one or Syntech in my new cars for the last ten years and the inside of the engines looked brand new after 100K miles! Note; I said new cars... Put Mobil one in my 1984 and it started leaking at the front seal... drained and put in Castrol 20-50... looking good. Was going to put Mobile One into trany... now I'm going with the Swepco. (from Pelican) FYI
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Why Porsche used a plug with an internal hex rather than external is beyond me.......I can see no engineering reason for it. If I could find a similar plug with the proper thread and an internal hex (like a proper pipe plug) I would use it!!
However....If the plug is seized, which is not all that unusual, this generally works: "Surround" the plug with a pair of Vise Grips, the kind with the curved jaws. This provides outside support to the plug. I have seen a number of these plugs with the hex broken open since the side walls are so thin. Once removed, please coat with Neverseeze or equivalent when reinstalling. The removal of a totally seized broken plug is not a pretty sight. Requires drilling and this introduces metal filings to the transmission oil. Good luck Bob S.
Bob S. former owner of a 1984 silver 944 |
stray shpould be chiming in hes an amsiol afficinado
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD ![]() 04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP ![]() http://www.eurocompulsion.net |
Yes, AMSOIL gear lube (75w90) is okay to use, and needless to say, I highly recommend it... I too have heard good feedback about SWEPCO. So... I think you'd be fine with either one. Good luck. Jim
Jim Griffin JGriff@JGriff.com 1990 944 S2 JGriff.com "Excite the senses, drive a Porsche!!"
