Aussie944S's Avatar
need one of thses bad boys
hey guys just did my Belts and pump, found the cover that goes around the cam sprocket difficult to put the bolts back in had to buy new ones that where a little longer. any way dunno where to find a part number for it i posted a pic so ya know what i'm on about.
Old 11-04-2011, 09:51 PM
Professional Bull5hiter
Outback Porsche's Avatar
The number for the genuine bolts is 900 074 015 02. I bought a set from Pelican a while back, they may still be available. According to the parts list, they are M6x30. You could probably pick up a passivated bolt from a local source and not have to wait the the three weeks delivery from the US. Being out here in the boonies, it's not so easy for me as it's about the same wait if I have to order from interstate.
Cheers,
Jeff
83 944 Guards Red
23 718 GT Silver
Old 11-04-2011, 10:11 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
A good procedure in aluminum blocks where bolts have been removed is to run a thread chaser (thread tap) of proper size with wd-40 to clean them and avoid seizing or re-thread problems. If thread lock is to be used later, a thorough cleaning with carb cleaner is needed. If your new bolts are longer, you could spin a nut on them and use a fine grinder to shorten them to the proper length and then spin the nut off and fine dress the end with a fine tooth file. This is a field process where you can't get the parts you need in a timely fashion.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 11-05-2011, 09:20 AM
