-   -   speedo sender not installed right. maybe? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/637835-speedo-sender-not-installed-right-maybe.html)
racer951y 11-01-2011 11:23 PM
I took off my speedometer sender when I was taking out my transaxle but only the sender and not the part that screws into the transaxle. When I got it all back together I seem to not uave a working speedometer anymore. This is on my S2 with a 5 speed
Did I miss a proper way to reinstall the sender?
racer951y 11-08-2011 11:29 AM
I just replaced the odometer gear and noticed that one of the wires to the speedo had its insulation rubbed off in a spot so I wrapped in electric tape and will see if that was the issue when I re-install the cluster.
v2rocket_aka944 11-08-2011 01:47 PM
I am not using the speedo sensor on my trans so if you need one I'd cut you a deal if you 1) know how to remove it and 2) know how I can plug the hole.
