-   -   high voltage issue (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/639823-high-voltage-issue.html)
looneybin 11-14-2011 08:29 AM
high voltage issue
I've searched the forum, but haven't found any info that is exactly what my issue is.
Last week i had to put my battery on a charger because the interior light was left on and drained the battery - i didn't disconnect the cables when i hooked up the charger.
When i started the car, the voltage gauge is reading very high, not up to the red, but damn close.
Is it possible that i fried the voltage regulator/alternator by using the charger?
When i add load to the system (lights, turn signals etc) the needle does slightly drop, but it's still above 14
Cocacolakidd 11-14-2011 10:20 AM
If you do not have any testing equipment take the alternator off and go to your nearest auto parts store and have it tested - it sounds like you fried the voltage regulator...
looneybin 11-14-2011 10:47 AM
i have a multi tester, what would i be testing for? the actual voltage at the battery?
Cocacolakidd 11-14-2011 11:28 AM
Check at alternator for 13V. or slightly below at higher RPM's (3K plenty)
looneybin 11-14-2011 03:47 PM
i'm getting 13.69 vdc at the battery at idle, the gauge was reading 14+
i also did the LED upgrade, could that be wacking out the voltage gauge?
I only replaced the 3 main bulbs, not any of the warning lights
