Endat's Avatar
Porsche 924 firing order
I've searched and read all I can stand and I can't get a clear idea of what order the wires go onto the distributor... I cant find an illustration ANYWHERE so I thought I would try this...
^ Pic is taken from the driver's side, sorry about the quality
The rotor points to A when at TDC but the "notch" is on D.. can someone please give me a clear answer? from what I've read it should be:
A = 1
B = 3
C = 4
D = 2
But the engine stops itself dead when I try to start it in that order...
2001 Porsche Boxster
1987 944S
Old 11-17-2011, 01:58 PM
Der zundfolge ist 1-3-4-2. I vould assume zat 1 iss TDC.
Old 11-17-2011, 02:17 PM
Endat's Avatar
Danke, aber das ist die Zündfolge von die Zylinderkopf.. ich kenne die Zündfolge von die Verteiler nicht..
1987 944S
Old 11-17-2011, 02:50 PM
lol
1988 944 turbo
Old 11-17-2011, 03:03 PM
924RACR's Avatar
You sure it's spinning the way you think it is?
Hmm... typing that first, I meant the rotor... but now I remember also that a 924S/944 starter will spin an NA 924 backwards, if installed... hope you're not fighting that?
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 11-18-2011, 03:51 AM
Endat's Avatar
Everyone says it spins clockwise.. My starter is toast anyway, need to replace it. if I post a pic of the starter can you tell me if its the right one?
1987 944S
Old 11-18-2011, 05:34 AM
924RACR's Avatar
No, sorry, they don't much look different...
I trust the crank is spinning clockwise?
FWIW, those cyl number placements do sound correct to me...
Vaughan Scott
http://www.924.org
Old 11-18-2011, 06:12 AM
