-   -   i need help with engine's negative pole (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/643079-i-need-help-engines-negative-pole.html)
PetrosS2 12-03-2011 11:11 AM
where is the correct place to connect it??????????????http://forums.pelicanparts.com/uploa...1322939436.jpg
Jrboulder 12-03-2011 11:17 AM
On my N/A and probably the S2 it bolted to the top of bell housing. A real PITA.
My ground cable went bad after I did my clutch and I replaced it with a cable running from the cylinder head to the body. I highly recommend it to anyone, although I haven't gotten around to installing one on my S2.
On another note, You've got an A/C delete S2??
Jackson
PetrosS2 12-05-2011 04:36 AM
yes is with out a/c.
