-   -   Exhaust bypass mod - Open to Stock with the flip of a switch! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/64396-exhaust-bypass-mod-open-stock-flip-switch.html)
CJFusco 03-31-2002 01:08 PM
What do you think of this exhaust modification? Worth it?
http://www.9xauto.com/images/bypas1.jpg
http://www.9xauto.com/images/bypass.jpg
Keep Your Dirty Secret Under Your Car
This is the thing you open to kick some a...
Absolutely will increase your HP gain. Instantly move from silence to thunder.
Remote control operated, this little device was constructed by JCW and is top quality. We recommend purchasing this device with a vacuum gauge to see the progress as the unit opens up. This is a cheap way out from spending a fortune on custom headers, performance muffler and free-flow cat. converter. Just remember, you have to install this bypass after the oxygen sensor.
CAST-IRON EXHAUST CUTOUT Dash control increases power, adjusts tone while you drive You two exhaust systems in one: (1) CLOSED QUIET EXHAUST for city and restricted areas; (2) WIDE-OPEN EXHAUST system for the open road and country driving when you want more speed, more power and gas economy. Made of cast iron. Requires welding. Mounts behind catalytic converter where applicable. With 5-ft. dash-control cable… Fits pipe 1-3/4" to 2-1/4" Note: Check local emission laws before ordering.
You can find this on http://www.9xauto.com/944.html
Bob's944 03-31-2002 01:24 PM
Instant power, yes, but also the instant and total attention of everyone within site and sound, including the guys with the extra pretty colored lights on their cars. Any doubt of whether or not you were really racing would be removed if they found your cut off pipe after wondering where all that noise came from.
CJFusco 04-04-2002 09:59 AM
bump*
overkill 04-04-2002 11:04 AM
I love it!
lordgrommit 04-04-2002 05:14 PM
this again . this is an old JC whitney catalog item... I'ts crap. it's made like crap your installing a perm exahast leak.
Matt
wolfrpi 04-04-2002 05:25 PM
Bolting on a heavy piece of cast iron (redundant I know) that leaks exhaust gases and is made by JC Whitney...hmmm. If someone reputable made it and didn't used cast iron for god's sake I'd consider it.
41V 04-06-2002 06:51 AM
how old??? yes, I do remember seeing this in JCW catalogs in the late 70's. I used to check every page of every issue back then and dream of stuff for my 70 Nova small block. Same, same picture, same text, probably NOS sitting on same shelf since then. Probably a pos.
Roger Hall 04-06-2002 10:01 AM
what did your car do to deserve that kind of punishment if you want to upgrade the exhaust system buy the right parts
