early 944 front wiper doesn't work
Hi All,
I have an 84 944 with a non-working (nothing happens) front windshield wiper system. This motor has been taken apart and scrubbed as well as greased. I am not really an electrical genius (nor a genius in anything else for that matter) so if anyone could point specifically to what I should try next that would be very much appreciated. Below are the steps I've tried so far based on other posts and the results. short version: ~11.8 volts at the wiper motor connector; motor seems to spin on a test bench long version: I turned the key on to enable the electrical system and I switched through the windshield wiper modes while looking at my multimeter which had its probes on the plug that the wiper motor (unplugged) normally connects to. The screen read ~11.8 volts for each wiper setting with the black/negative probe touching the ground and the positive/red probe touching whichever contact was active. Also, I placed the wiper motor on the ground and connected it directly to the battery. After a bit of trial and error, the motor did spin and hum (unless out of desperation I imagined it happening). On the other hand, the motor is silent and doesn't budge when I install it in the car and hook it up to its connector. The wiper blades have been taken off. The motor has been scrubbed to remove a fair amount of rust and dirt from the interior but it did not look as bad as some other examples from message-boards. So, all in all, it seems the motor is probably working; the selector switch and fuse must be working (right?) for there to be 12 volts at the connector. I just don't understand what exactly to check next and why it hasn't worked yet. Thanks! |
Check your grounds...
Thanks for the tip, 944 Ecology. I guess this below from 924.org is the procedure I will try to follow.
How-To Electrical Diagnosis Quote:
tap on the motor housing, maybe a brush is stuck?
| All times are GMT -8. The time now is 01:43 PM. |
