somaa62008
Porsche Crest 924 Dosent start :(
Hi guys i need a little help..
My 924 had a leaky fuel accumulator, i replaced it, but its steel dosent want to fire up?!£$
i checked i dont see leak on the rubber air hose so the air delivery i think tight! as i took off the air filter and if i press depress the rubber part the little valve (gate) is lifting up. What i find that the temperature sensor (unit) dosent have continuity when i check with a DMM.
Can anyone help me why it dosent start just runs for a secound or untill i keep turn the engine with an ignition on and the starter motor spins the engine. But it sounds runing and the exhaust blows. Like dosent get fuel after ignition.?!
Old 11-15-2011, 05:08 AM
Toofah King Bad
Rasta Monsta's Avatar
First diagnostic step on any CIS car is the last step most people want to pursue. . .buy a CIS pressure tester and check your system and control pressures. Without this information, all anyone can do is guess.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-15-2011, 08:13 AM
somaa62008
Is there any other a bit cheaper way ?! Is there any common fault with this system except the fuel pump and accumulator fault those been sorted.
I can`t buy this cis pressure tester, only from the USA £75 ...
I tryed to lift up this plate valve thing on the unit by removing the air filter,but it just made it worst, it didnt even fire after when i put igniton on!
Like didnt get any fuel ofcores cause no pressure.. so it means i do have pressure by the air and my fuel pump keep pumping every single time i turn the ignition on, i just dont understand what is wrong. Fires but only until the starter works..
what about fuel pressure regulator valve ... ?! is there any common problem with thise things
Or there is no way i have to check the pressure ???!!!
Old 11-15-2011, 08:47 AM
somaa62008
Where is that little kick comeing when it fires for a sec ? warm up regulator?
Old 11-15-2011, 08:48 AM
fiat22turbo's Avatar
Considering the number of Bosch CIS-equipped cars produced over the decades, I can't believe that you can't find one locally in the UK.
924Board.org :: View topic - CIS Fuel Pressure / WUR test
Bosch Fuel Injection Systems - Bosch K-Jetronic
Home - CIS Flow Tech
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 11-15-2011, 12:19 PM
somaa62008
thanks!!
Old 12-17-2011, 07:18 AM
Toofah King Bad
For a starting point to understanding the system, I refer people to this article:
Auto-Solve Diagnostic Assistance
Old 12-17-2011, 09:50 AM
You might be able to borrow a Pressure Tester from one of the forum members in the UK.
http://www.google.com/url?sa=t&rct=j&q=porsche%20924%20forums&source=web&cd=10&sqi=2&ved=0CH8QFjAJ&url=http%3A%2F%2Fporsche924.co.uk%2Fforum%2F&ei=W3ztTtybKs2EtgeI7eDjCg&usg=AFQjCNFI3YGczSEuBJNZrdFiF0CkjHYcsg
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 12-17-2011, 09:49 PM
