wilkrod's Avatar
944S valve stem/guide clearance
Hi all,
For an 87 944 S, I am wondering what the excepted service limit would be for valve stem/guide clearance for intake/exhaust valves?
I would like to measure each valve guide I.D. with a pin gauge, or bore gauge, and then measure the corresponding valve stem O.D., do the math and determine if the clearance is acceptable for a used part.
Trying to determine if valves/guides should be replaced by using a direct measurement , just don't know what the clearance numbers should be.
Thanks Much
Jeff
Old 12-22-2011, 07:50 AM
I understand what you are asking here, but I have to ask, why not replace the all the guides. I am in the same boat as you. Having removed the head on my 8valve, I need to replace one exhaust valve guide. From talking to people, and I may be wrong, but all have said to replace all the guides and seals. From what I understand the guides wear, and are supposed to, the valves not so much.
From what I understand replacement valve guides are .0025 larger in diameter, as the originals are nla.
This stuff is all new to me, so I am assuming that the head is going to need some machine work to accept the new guides, or will the replacements press in with enough force. (from a press)
I am interested in what you find out from this thread....
Originally Posted by wilkrod View Post
Hi all,
Thanks Much
Jeff
86NA944
Old 12-22-2011, 08:31 AM
C ANDERSON's Avatar
Jeff,
I have the service book for the 2.5 S head . I will be away from the shop untill the weekend but would be glad to copy and E-mail it to you, Its only 3 pages. If I remember correct they use the tilt play method and it is at 10mm valve stroke with a wear limit of 0.80 mm
Clifton
Old 12-22-2011, 05:33 PM
