Clutch issues
Ok just bought an '86 944 with the clutch pedal on the floor. I saw a puddle of brake fluid under the the car and figured it was the slave. After getting under it that was confirmed by seeing the fluid spill out of the opening by the slave cylinder. I replaced the slave and bleed the system.......still on the floor. I figured I did a poor job bleeding so I tried that again.......still on the floor. I took off the slave again and noticed the lever it presses on has no resistance, it just moves back and forth. Hopefully I'm an idiot and did something wrong. Please what ever advice you got I'll take.
Thank you
Old 12-15-2011, 05:34 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
The lever that the Clutch Slave presses on is the Clutch Actuating Fork. It should have full pressure on it at all times if all is well. Otherwise the fork itself or the clutch pressure plate is faulty and one or the other will need attention.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 12-15-2011, 08:25 AM
winter-hater club member
nynor's Avatar
incorrect assembly of the throw out with the spacers and such, and the whole thing is just sliding on the shaft. time to pull the whole thing apart. sorry, man.
"COOL PRIUS!" - Nobody Ever
Old 12-15-2011, 10:08 AM
How would I know which one it is? And would starting while in gear cause that issue by chance
Old 12-15-2011, 10:14 AM
I know it was working fine a few weeks ago. Could the slave going bad cause that issue? What are the odds both had a problem at the same time?
Old 12-15-2011, 10:27 AM
Toofah King Bad
Rasta Monsta's Avatar
To be clear, the clutch actuating arm moves completely freely, hitting the front and the back of the window it pokes out of?
If so, something is broken in the bellhousing, likely the clutch fork itself.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-15-2011, 10:52 AM
What does fixing something like that entail?
Old 12-15-2011, 11:28 AM
Toofah King Bad
Drop the trans, pull back the torque tube, pull the hellhousing.
Old 12-15-2011, 12:10 PM
nynor's Avatar
no. the improper assembly may have caused the slave to fail when it allowed the slave piston to move so far forward.
as stated above, you are going to have to pull it all apart to find out what failed. that sucks.
Old 12-15-2011, 01:41 PM
Ok to "pull it apart" how hard is that to do ie should I get a pro to do it?
Old 12-15-2011, 03:19 PM
nynor's Avatar
well, what is the most difficult mechanical repair you have performed on a car?
Old 12-15-2011, 03:48 PM
Rebuilt the front end on a 1970 opel gt with a transverse leafspring. I guess would be the hardest.
Old 12-19-2011, 09:12 AM
How much did you pay for this car? My guess is the PO knew what was wrong and didn't want to pay for the repair, or he could not do it himself. That should give you an idea about the level of difficulty, and the cost of repair. I hope it is something easy tho.......
86NA944
Old 12-19-2011, 10:54 AM
Yeah that would be something people may do but this kid had no idea about the issue.
Old 12-19-2011, 12:43 PM
nynor's Avatar
clutch on the 944 is probably easier. it is pretty straightforward, but time consuming, and some of the bolts and such, especially at the bellhousing, are very tight. hell, i replaced a 944 clutch with my friend. i've done a LITTLE work on an opel GT, and i don't think that the 944 is nearly as obtuse.
Old 12-19-2011, 01:48 PM
Well, if it was working fine a few weeks before, it could just be a bad slave cylinder. Keep bleeding until you get pressure. Or rent a power bleeder from an auto parts store to make the bleeding easier. 944 is a pain to bleed without a power bleeder.
Absence of pressure in the lines due to air bubbles will keep the lever you mentioned loose.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 12-19-2011, 01:58 PM
nynor's Avatar
bazar, you missed the part in the OP where it says that the clutch arm has no resistance. it is moving freely. AFAIK, no amount of bleeding is going to fix that.
Old 12-19-2011, 02:01 PM
Toofah King Bad
He never really said if the arm traveled completely across the "window" though. . .
Old 12-19-2011, 02:05 PM
I'm not sure on that one. I'm going to go check and see.........If it does not go all the way could it still be a crappy bleeding job on my part?
Old 12-19-2011, 04:06 PM
nynor's Avatar
if it is moving freely, the round side of the 'cup' will be able to hit the end of the window.
Old 12-19-2011, 04:09 PM
