Jon C
jonjchris's Avatar
924 starts but dies as soon as the key is released.
Hey all,
I would love your thoughts. My 78' 924 has been giving me problems the last few days. I am just getting it ready to park for the winter and it now won't start. One day last week I was driving and it kept dying on me. Some times is would start right back up and other times it would start and die as soon as the key was released. Right now it turns over and starts but as soon as I release the key it dies consistently.
I replaced the ignition switch last spring when it was having similar problems.
Thanks for the help.
Jon
78' Porsche 924
01' Chevy Monte Carlo SS
Old 12-22-2011, 02:32 PM
Toofah King Bad
Rasta Monsta's Avatar
Will it start if you jumper the fuel relay? Did you use a good OEM quality ignition switch? There are some very crappy ones out there.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-22-2011, 02:43 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Check all grounds - Check wiring to starter motor - check wiring and plugs at Ign. switch...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 12-22-2011, 02:45 PM
This happened in my '84...
The problem is in the ignition switch where once you let go of the 50 track ("start" position) it goes to a little spot clockwise of the contact for the 30 track ("on" position). It happens when a cheap ignition switch is used and it wears this gap between the contacts. The way you can test for this is to immediately put a little counter-clockwise pressure on it after the engine starts to hold it against the contact before the engine dies.
Old 12-22-2011, 03:42 PM
Jon C
jonjchris's Avatar
I have confirmed that the problem is the ignition switch again. I guess I should have known better than to put a cheep one in. Live and learn.
78' Porsche 924
Old 12-22-2011, 07:03 PM
