Porsche Crest 924S Cylinder Head Nut Torque Specs
Does anyone have a procedure and specs for tightening cylinder head nuts on a 1987 924S? My Haynes book says call the dealer which I will do if nobody has this info. Thanks.
Old 07-31-2009, 06:44 PM
Found the answer at www.clarks-garage.com. It is a three step process with the final torque at 66 ft-lbs.
Old 07-31-2009, 09:16 PM
Proprietoristicly Refined
John_AZ's Avatar
Jeff you are wrong. It is a 3 step process for the 1987 924S;
Step one 15 pounds
Step 2 90 degrees
Step 3 90 degrees
http://www.clarks-garage.com/pdf-manual/cyl-03.pdf
Follow sequence per Clarks.
Wait 45 minutes to 1 hour between steps to let head and gasket set
Tap the perimeter of the head with a hammer softly to "set" the head and even the force.
The washers can be reused if scruffed on bottom. They cannot move when torqued.
Lube the head bolts with oil befor process
Get new nuts (head bolts in some catalogs)
Take your time and make sure the surfaces are cleaned with acetone and all gasket material is gone.
GL
John_AZ
1988 924S + 1987 924S ----Head Gasket '07
Old 07-31-2009, 10:14 PM
Check your engine number.
The engine # will dictate the tightening steps whether its a torque value method or angle method.
M44 05-08, as you have stated by torque value
M44 05-10, as John had stated by angle
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 08-01-2009, 04:26 AM
John_AZ's Avatar
Thanks bazar01,
I went by the size of my head nuts-12mm high per Clarks on my 1987 924S.
GL
John_AZ
Old 08-01-2009, 04:41 AM
Send a message via AIM to hpaulb
Can someone clear this up. What does this mean? Follow the bolt pattern, each nut to 15 lbs then for step 2 and 3 turn each not an actual 90%? What is the final torque supposed to be?
Step 1: 20 Nm (15 ft-lbs)
Step 2: 90° angle
Step 3: 90° angle
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 12-29-2011, 02:26 PM
That Guy
Techno Duck's Avatar
There is no final torque value. The factory procedure uses a method called torque angle. It means torque the nuts initially to 15ft-lbs, then turn each fastener 1/4 turn (90 degrees), then another 1/4 turn. I like to wait about an hour inbetween each stage to allow everything to 'settle'.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-29-2011, 02:41 PM
John_AZ's Avatar
Step 2: 90° angle
Step 3: 90° angle
Important
Light oil on the head threads and do not let the washer move. Scuff the washer bottom and mark to make sure.
Final Torque???
Here, this will mess up your mind if you do not follow the 15 ft lb, 90+ 90 degree method.
Torque angle gauge and head bolts - Over torqued? - Rennlist Discussion Forums
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 12-29-2011, 05:09 PM
Toofah King Bad
Rasta Monsta's Avatar
Listen to John, he is the Head Nut.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-29-2011, 06:56 PM
John_AZ's Avatar
Best to all in 2012.
John
Old 12-30-2011, 04:46 AM
Anyone ever write down what the final is? Today i did the first to 15lbs. An hours or so later i went over the head with a wood mallet taping to help seat???. Did the the second to 90 deg. Actually hard to Gage/guess an actual 90 deg. Did it with the old fastened torque bar and they were relatively close to 65 lbs.
What should the next 90 deg give me?
98 BMW 740i
Old 12-31-2011, 02:13 PM
