New Member
Trouble getting a good radiator fan connection
Every now and then, one or the other of my radiator fans won't come on. If I wiggle the connector it comes on until I hit a bump, or it just decides to stop. I've cleaned the connectors, but it still has the same behavior. I'm thinking either the wires are brittle and snapped or it's in the motors themselves. Has anyone else had this problem?
70 911T Targa (major salvage operation)
72 911T
85 944
2011 Cayenne S
98 GMC sierra
Old 01-21-2012, 10:53 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
intermittent fans
Get a volt meter, some small "SPADE LUGS" from Radio Shack or auto parts store that are the same size as the prongs in the fan plug. Crimp wires into them and insert them into the connector on the wire harness. Attach the VOM to the end of the wire leads and them manipulate the wire harness, connector and watch the VOM for fluctuations. If your readings are solid then you either have a bad or corroded connector on the fan unit or where the wires go into the fan motor. Also check the connector on the temp switch. It could be that the fan is running due to higher temp and then stops due to bad connection on the temp switch. Remember that the fan also comes on due to the A/C being on. Good luck.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-22-2012, 05:50 AM
944 addict
intermittent fans
Get a volt meter, some small "SPADE LUGS" from Radio Shack or auto parts store that are the same size as the prongs in the fan plug. Crimp wires into them and insert them into the connector on the wire harness. Attach the VOM to the end of the wire leads and then manipulate the wire harness, connector and watch the VOM for fluctuations. If your readings are solid then you either have a bad or corroded connector on the fan unit or where the wires go into the fan motor. Also check the connector on the temp switch. It could be that the fan is running due to higher temp and then stops due to bad connection on the temp switch. Remember that the fan also comes on due to the A/C being on. Good luck.
Old 01-22-2012, 05:51 AM
Marajit's Avatar
Connector on the fan unit.
Soldered joints burn out.
Third world solution is to pull the fan plastic connector completely off and attach the wire harness connector directly to the prongs.
Peace to the Brave
1983, 1984, 1987 944 N/As
Old 01-22-2012, 03:47 PM
