Banned
any way to tell what spring rates are
obviously, you can measure them with a known weight, but anything besides that? stampings? labeling?
Old 01-16-2012, 09:25 AM
968 GUY's Avatar
There are paint dots on the springs. Not sure of how the codeing works on that, but may be in the workshop manual.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 01-16-2012, 09:39 AM
Banned
where are these dots?
Old 01-16-2012, 01:12 PM
9FF 9FF is offline
9FF's Avatar
The dots are on the coils of the springs. They are just dabs of paint really not dots, should be three close together that can be deciphered in the manual.
If your springs are stock you can look them up here by model/year (page 5):
http://clarks-garage.com/pdf-manual/susp-15.pdf
Old 01-16-2012, 02:16 PM
'68 911 / '86 944
Spring rates are easy to determine. Just measure diameter of the coil and wire. Count the number of coils and calculate. You don't even have to take them off the car to measure and calculate.
Equation: k = Gd4/8nD3
Having a little trouble getting the upper case font. That equation is d to the 4th power and D to the 3rd.
Where:
k = Spirng Constant, pounds of load per inch of deflection
G = modulus of rigidity of spring material, = 12,000,000 lb/in2.
d = wire diameter, inches
n = number of active coils, which is the number of coils subjected to flexure
D = mean coil diameter, inches = Outer Diameter - Wire Diameter
Weltmeister Green Stripe
Suspension Coil Spring Rate Design Equations Formulas Calculator
Old 01-16-2012, 04:53 PM
Banned
thanks, i bought some koni cored struts and didnt know if the PO had aftermarket springs on it them, it appears he did not. which is exactly what i needed to know, thanks!
Old 01-16-2012, 07:00 PM
Toofah King Bad
Rasta Monsta's Avatar
Where:
Quite interesting. So, the number that we get as a result of applying this formula, is it consistent with what we all call "250# springs?"
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-16-2012, 09:41 PM
