oil check valve.
What are the symptoms of having it incorrectly installed. Thought i did a good job but this third engine runs with higher oil pressure than than the first two. cold or high RPM's it's around 4 bar. Runs 2-3 bar when hot and running slower.
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 2020 Subaru Outback and 2019 Crostrek. |
AFM #725
I thought that was normal
absolutely normal 4-5 cold or above 2500, 2-3 hot idle
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
