Fuel Rail Sealing Ball
Hi, Trying to check fuel pressure on my 1986 NA, I've removed the cap and the sealing does not want to come out. Any hints or tips? Thanks!
Magnet?
Good luck, George Beuselinck |
Thanks, didn't work. Holding off on the blow torch for now.
Rap on the fuel rail with a block of wood and and hammer?
Spray carb cleaner around the sealing ball? Last edited by Spring44; 02-12-2019 at 10:55 AM.. |
Small strong vacuum of some kind?
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway) Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver |
Place rag or container over port, blip the ignition key to crank the engine on and off quickly, and let the fuel pressure pop it out.
Thanks all, I'll give them a try tomorrow and let you know.
Amatuer Hour Specialist
Disconnect small hose near fuel damper, use compressed air.
screw the cap back on - back off a turn hold a hammer on one flat side and smack the opposite side with an other large wrench or hammer - take the cap back off. - don't drop the ball.
