later engine for 83 944
has anyone installed a later engine into a 83 944? and what kind of issues are there,is it worth it?
Old 01-24-2012, 12:01 PM
"worth it" is relative term.
what are u trying to accomplish?
Old 01-24-2012, 01:23 PM
I'm replacing the engine due to a broken timing belt,so I was wondering if I could put a better engine then the one removed
Old 01-25-2012, 02:10 PM
Toofah King Bad
Rasta Monsta's Avatar
How much you wanna spend, son?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-25-2012, 02:38 PM
on one hand, you have your original engine, that has broken timing belt and damaged valvetrain in gradient of "almost none" to "catastrophic". which will cost between $200 (tb+wp kit) and $1500 to get back to running order
on the other hand, you have some used engine that someone's selling that either ran recently or condition unknown. once u get that engine, u'd really want to spend an additional $300-500 replacing tb+wp, rod bearings, main bearings, seals, whatever else.
your choice
Old 01-25-2012, 03:27 PM
the guy's up at porshe heaven,think it should be replaced,you think I should pull the head and see for myself,there selling a long block for $900,
Old 01-26-2012, 11:50 AM
there are a few differences beatwean new and old engines but if you have it two then are easy to swap:
mecanical
-crankshaft pulley
-alternator braket(maybe if ramin yours don't need to change but cheac it)
-alternator and AC belt
-metal heathing hose on exaust side
-fuel rail(intake and exaust f gas tube)
electric
-gauge temperature sensor(not same jack and dimension)
-AFM
-maybe alternator but i'm not sure-different bracket
the alternator/ac/crankschaft pulleys are differnt because of slightly differents belts so try to mach yours cars setup(same pulleys and conponents) and you don't have troubles
But if is only a head job and only the valves are worn it is easy to just replace the valves(used ones),take a head gasket rebuild kit and a timing kit to be in peace.
If you take apart the engine take a look to the clutch,it's easyer when is out
a head gasket job is normal on every car that have more than 10 years
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 01-26-2012, 01:41 PM
kens_74_911s's Avatar
84 engine
Hi I have a good 84 944 2.5 engine I can sell you the long block for $400 its just about ready to be pulled from the car.
i'm in NC Ken
autotech@nc.rr.com
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 01-27-2012, 12:44 PM
whats wrong with it?how many miles on it? how much would it cost to ship to Calif?
Old 01-28-2012, 08:29 PM
