944 NA - A couple of topics
Hello there!
1) I got a brand new set of wheels (MSW cheap but looks very good), they say:
7Jx16 ET23
8Jx16 ET11
What would be the best looking option in terms of tire size?
Porsche recommends 205/55 front and 225/50 rear, but I read everywhere 225/50 front and 245/45 rear (?)
2) Radiator replacement.
This is AT, so the radiator helps also the ATF to stay cool --> harder to be replaced (I think) and no instructions at all.
Abybody there did this job? Can you assist me by wirting step by step instructions?
Thanks for any help!!
Old 01-23-2012, 11:41 AM
unindicted co-conspirator
looneybin's Avatar
Have you checked Clark's Garage Home Page for the info on the radiator replacement?
It shouldn't be too hard of a job, there may just be extra fittings for the trans cooler?
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 01-23-2012, 12:44 PM
Yes you're correct, but how to restore the ATF that goes out of the circuit?
Clarks says "On models with automatic transmissions, disconnect the transmission fluid hoses at the radiator and plug the holes" which sounds ok but not enough I think...
Old 01-23-2012, 12:59 PM
Toofah King Bad
Rasta Monsta's Avatar
I wouldn't worry about losing a small amount of fluid. On the contrary, I would take the opportunity to drain it completely and renew the fluid.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-23-2012, 01:36 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Tire Sizes -
While Porsche recommends the use of the 205/55-16 front and 225/50-16 rear for the best overall gas mileage, and this includes speedometer settings. The larger size tires, 225/50-16 and 245/45-16 will probably be slightly better on highway longer miles for gas mileage. The smaller (Ever so slight) 225/50-16 will be better for stop and go performance and mileage.
Speedometer calculations are very close on both sizes. If you have a '83 to '85 with the front wheel speedo drive when you are doing 60mph with the 205/55-16 front the larger 225/50-16 front tire will actually be doing 59.5mph - to close to bother. If you have a 85.5 and up with the 225/50-16 in the rear and the speedo is registering 60 (Electronic rear speedo drive), but with the larger/wider 245/45-16 in the rear you will actually be doing 59.8, again very close.
So your choice between looks and the possibility that the smaller tires may be slightly more responsive in stop and go driving - or ??
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 01-23-2012, 02:24 PM
9FF 9FF is offline
9FF's Avatar
Go with 225/50 front and 245/45 rear, more traction, better braking. Size isn't an issue for speedo reading. It will either read a tiny bit high or low depending on the tire brand, negligible.
Old 01-23-2012, 02:50 PM
Thanks for the advice.
Still in doubt because of the ET of my wheels.
Today the wheels have arrived (old MSW wheels). After the upcoming refurbishment, begin of April I'm going to install them.
My car has no ABS, what would be the car look with 245 in the back and 225 in front? I don't want a super aggressive look..
That's the question!!
Old 01-30-2012, 02:09 PM
