Tired Member
DaddyGlenn's Avatar
Question Thoughts on '84 944
1984 944, automatic has been sitting for 10 years in a garage. Engine turns over but no spark. Owner has replaced battery and DCE. Otherwise in very good shape. Only 65k miles.
I'm thinking about buying. Any thoughts on what I could be in for?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 03-23-2012, 04:46 PM
Lots. Auto rubber trans dampener is probably cracked and may need replaced after you get the car running and start driving it. A 944 that has been sitting that long will have many issues like crudded up gas tank, gas lines and injectors. Belts should be done right away before you attempt to crank the engine over anymore and while you are in there might as well do the water pump too. No spark could be computer, reference sensors, coil, ignition switch or some other issue like a mouse getting hungry in there. If it were me and I wanted a 944 I would find a clean nice running example. They are out there and with this economy you can find a good one at a good price. My 2 cents.
Old 03-23-2012, 04:58 PM
FrenchToast's Avatar
The early (pre 1985.5) cars only had 5-digit odometers. So that claimed mileage could be 65k, 165k, 265k, etc.
The no spark could be a bad reference sensor or DME, or either not being fully plugged in. Or a mouse has eaten any of the relevant wires. Or of course, it could be the spark plugs and other more obvious stuff.
Standard upon-purchase maintenance for these 8V cars includes checking and replacing the timing belt, full fluid flush, etc.
Old 03-23-2012, 04:59 PM
Amen!
All true, however a running 944 in good shape almost has no equal. I have a relatively low mileage model, I have changed more !@#$% parts on it than ones I see being driven regular. Patience... you'll need loads of it with these babies.
86 951 blk
Old 03-23-2012, 05:08 PM
FLYGEEZER's Avatar
I've had my 1984 944 automatic since 1999 purchased from the original owner. However, the car sat in a dry garage for about 5 years, never driven. No abuse and 105,000 SERVICED & DOCUMENTED miles. Let me tell ya, your gonna spend a lotta money. The dampener alone cost $1100.00. And it's gonna go, I promise you. Despite it all........ I don't regret a dime spent to make mine what it is. Enjoy!
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 03-23-2012, 05:17 PM
Proprietoristicly Refined
John_AZ's Avatar
DaddyGlenn- Tired Member
+1 zedsn
Automatic tans flex damper = $1200 just for the part.
If you are still thinking about it, the 3 speed auto is only good for long commutes if you get it running---not the car for a Tired Member.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-23-2012, 05:21 PM
Tired Member
DaddyGlenn's Avatar
Thanks everyone. The damper price is enough for me to walk away from an automatic. I'll keep looking....
Glenn
Old 03-23-2012, 05:30 PM
