tie rod assembly
Hi all, I'm wondering if anyone has fitted new tie rod assemblies to their steering rack whilst still on the car, if so anything to look out for please?
944s2
Old 02-18-2012, 12:29 PM
I did the inner and outer tie rods with the steering rack still on the car. Nothing tricky, that I remember.
2010 Cayenne GTS
Old 02-18-2012, 03:38 PM
That Guy
Techno Duck's Avatar
Its pretty easy to do on the car. Check the section that threads onto the rack, if the tie rods were installed correctly the last time the ends should be peened. You may need a small chisel to break that section off (sounds difficult but its very easy) to unthread the tie rod.
There is a tie rod removal tool available that makes installation and removal super easier if your willing to lay out the $50 for something you may use 2-3 times in your wrenching lifetime.. Inner Tie Rod Removal Set
I have a set and it makes it super easy to do.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-18-2012, 04:42 PM
Thanks for your replies, glad it can be done without removal. Just a bit concerned about straining the rack undoing and tightening the tie rod assemblies. Thanks for the tool link, although the shipping to the uk might be too much for the use it will get.
944s2
Old 02-19-2012, 05:00 AM
Toofah King Bad
Rasta Monsta's Avatar
You are right to be conerned. . .rack should be in a bench vise to protect the steering gear from tightening torque.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 02-19-2012, 10:22 AM
Yes, that is a worry, is there a torque figure for the assemblies?
944s2
Old 02-19-2012, 10:30 AM
Toofah King Bad
85 Nm/61 ft lb
Old 02-19-2012, 10:46 AM
Thanks for reply, it's very helpful, just got to see if I can counter the torque effect by gripping the rack without damage, looks like there maybe 2 flats to grip on the main shaft whilst tightening the tie rod assembly, not too clear in manual.
944s2
Old 02-19-2012, 01:03 PM
